What size tire can I put on 18x7.5???
Old Aug 27, 2003 | 02:07 PM
TIGHT-Z's Avatar
TIGHT-Z
Arrow What size tire can I put on 18x7.5???
I want to get these rims but they only come in 18x7.5, and I want to run 265 in the back and about 245/235 up front. Will these tires fit on the rims.
Old Aug 27, 2003 | 03:09 PM
Sillent Killer's Avatar
Sillent Killer
The 235/245 will fit. You need 18x8.5 to fit 265 tires though.
Old Aug 27, 2003 | 03:31 PM
MATIX's Avatar
MATIX
Default Re: What size tire can I put on 18x7.5???
18x7.5" in hte rear is a honda civic size rim, for a Z you need something much larger...waht rims only come in 18x7.5"??
Old Aug 28, 2003 | 04:18 AM
TIGHT-Z's Avatar
TIGHT-Z
Default The...
every site I go the 5ZIGEN copse(sp?) says only 18x7.5??? But I need to run 265R/245F.
Anyone know the weight of the stock rims without the tire?
Old Aug 28, 2003 | 05:55 AM
lowrider's Avatar
lowrider
The 245/40s up front would be fine (though an 8 to 8.5" rim would be better. I know of no 265/40 for the rear. The 275/40 is the same hight as the stock 245/45s and would be the right size for the back. It would require a 9.5" rim however.
Lou
Old Aug 28, 2003 | 11:57 AM
Todd@ProDyno's Avatar
Todd@ProDyno
Yea...you will definitly need to step up a bit to a 2 piece special order version of that wheel and do 18x8 and 18x9s.
Old Aug 28, 2003 | 12:13 PM
D'oh's Avatar
D'oh
Why do you need to run that tire size? Do you already have the tires?
You could run those wheels with the stock tire sizes:
225/45-18 F
245/45-18 R
Anything above 245 is stretching it on a 7.5 rim.
-D'oh!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
DarkCreep
Oct 17, 2015 11:50 PM
Paul.
Oct 16, 2015 07:34 PM
kyin
Oct 15, 2015 05:54 AM
