Spacers: Rear Work Meister S1 19x10.5 +23
Old Jan 7, 2009 | 01:57 AM
InZpire's Avatar
InZpire
Default Spacers: Rear Work Meister S1 19x10.5 +23
I'm planning on rolling my rear fenders and sticking a some spacers.
How much can I go without rubbing?
Would I need to have extended or longer lugs?
thanks!
Old Jan 7, 2009 | 04:32 AM
fatboy.yoshi's Avatar
fatboy.yoshi
what size tire? and ride height?...
Old Jan 7, 2009 | 06:17 AM
lgear080's Avatar
lgear080
Without details I think you should stick w a 10 mm spacer from ichiba/kics,
and get a set of new nismo extended studs. My pref is 245/275 35 series
tires fyi.
Old Jan 7, 2009 | 12:07 PM
InZpire's Avatar
InZpire
Details:
275/35
Tanabe G210s
Old Jan 7, 2009 | 12:12 PM
lgear080's Avatar
lgear080
15mm might look better, but also might require a camber kit...
Old Jan 7, 2009 | 12:29 PM
madpanda's Avatar
madpanda
I knew you were gonna end up keeping it bro.
You should call john or Nino our offset masters.
But I think you can get away with running the 15's
Old Jan 7, 2009 | 01:36 PM
str8dum1's Avatar
str8dum1
a 10.5" with a +8 offset without a tire stretch fits on a dropped car with just rolled fenders? How much camber. greater than 2 degrees?
hmm, maybe i shoulda ordered bigger spacers.
Old Jan 7, 2009 | 02:20 PM
Triple8Sol's Avatar
Triple8Sol
Go with 15mm spacers. 20mm if you want to be aggressive.
Old Jan 7, 2009 | 06:34 PM
InZpire's Avatar
InZpire
I know! haha! Might as well :P
Ill wait for Nino to get back. He had the same exact setup before.
Old Jan 7, 2009 | 06:36 PM
InZpire's Avatar
InZpire
Do you have any pics of the 2 in comparison?
Can I run 15mm without extended lugs?
Old Jan 7, 2009 | 09:51 PM
str8dum1's Avatar
str8dum1
u can barely run 5mm without extended lugs, so no.
Old Jan 9, 2009 | 03:25 AM
InZpire's Avatar
InZpire
Are extended lugs generally safe? I know it sounds like a stupid question but just wondering.
Old Jan 9, 2009 | 06:43 AM
lgear080's Avatar
lgear080
IMO the oe lugs are of "acceptable" standard.
Nismo aftermarket extended lugs seem to be of higher quality.
davidm350
Oct 31, 2015 02:28 PM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
