255/50 on stock 17x8
Old Jan 11, 2009 | 06:09 PM
ag4670's Avatar
ag4670
Default 255/50 on stock 17x8
has anyone ran 255/50 in the rear of stock 17x8? Needing to get some new rear tires and was seeing what i could run with out having problem like coming of the bead and etc itll also be driven daily.
Old Jan 11, 2009 | 06:18 PM
255 mm tire on a 8.0 inch wheel! Are you crazy!
Old Jan 11, 2009 | 06:22 PM
andrewrfl's Avatar
andrewrfl
I'm running 255 but don't remember if its /30 or something else.
Old Jan 11, 2009 | 06:25 PM
ag4670's Avatar
ag4670
well 245/50 would work fine but not many compaines make them plus its almost 200 a tire with a discount tire dealer licence thats why im looking into 255
Old Jan 11, 2009 | 06:26 PM
Question
What size front tires are you running?
Old Jan 11, 2009 | 06:29 PM
ag4670's Avatar
ag4670
whats the tire size your running in the front? i got the stock 225/50 and read that its not good to have a higher profile in the front then the rear
Old Jan 11, 2009 | 06:32 PM
Front: 225/50
Rear: 255/50
90 percent certain this will not cause a VDC or TCS problem.
Old Jan 11, 2009 | 06:34 PM
ag4670's Avatar
ag4670
90% is better then my 50% thanks for the help
Old Jan 11, 2009 | 06:35 PM
sk26dett's Avatar
sk26dett
I ran a 255/50 on my stock 17x8" rims and they fit perfect.
Old Jan 11, 2009 | 06:39 PM
I always include the 90 percent disclaimer incase it doesn't work. TCS allows considerable leeway. VDC can be finicky.
Old Jan 11, 2009 | 08:10 PM
Smoothy34's Avatar
Smoothy34
I've got 255/45 17's on the rear of my car and no problems at all, practically the same diameter as the stock 235/50's that were on there...225/50's on the front but when i get new fronts going with a 245/45 probably. My tire shop told me if you go up 2 section width sizes go down a profile size and they're within a % or 2 of stock. No problems at all with the TCS in mine. I used this to check out his info: http://www.miata.net/garage/tirecalc.html
Old Jan 11, 2009 | 08:33 PM
nismo212's Avatar
nismo212
i got 225/50 front and 275/40 rear ventus on my 2003 with 17s
