Gram Light F-Pro Pics
Old Aug 31, 2003 | 11:56 AM
Topics II's Avatar
Topics II
Default Gram Light F-Pro Pics
Hey guys, i finally got pics of my gram light f-pros installed. they are 18x9 +24 and 18x10 +22. I would recommend +22 for the front cuz i had to have 2mm spacers cut to clear the brembos. Tire sizes are 245/40/18 front and rear.
Old Aug 31, 2003 | 11:58 AM
Topics II's Avatar
Topics II
the rear still has some wheel well gap cuz i am still waiting for my JIC camber rods!!!
Old Aug 31, 2003 | 11:59 AM
Topics II's Avatar
Topics II
front wheel
Old Aug 31, 2003 | 12:48 PM
skippyracer7's Avatar
skippyracer7
WHOA That is sweet.
Old Aug 31, 2003 | 12:55 PM
Moroccan_Mole's Avatar
Moroccan_Mole
those look big for 18s. very nice.
Old Aug 31, 2003 | 01:07 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
why did you do the same size tires all around with a staggered width?
Old Aug 31, 2003 | 01:26 PM
Topics II's Avatar
Topics II
I run the 245's all around for drift reasons. I dont wanna run a wider tire in the back cuz even with the procharger, itll be hard to spin at 80+mph. the 10's look nicer than the 9's and give the tires a sweet stretched look too.
Old Aug 31, 2003 | 04:44 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
didn't know you can put a 245 on a 8x10 wheel without any problems.. but the wheels does look good!
so is that still stock height?
Old Aug 31, 2003 | 05:45 PM
Selski12's Avatar
Selski12
Wow, those wheels look good!
Old Aug 31, 2003 | 05:55 PM
RaySur350GT's Avatar
RaySur350GT
YES! YES! YESSS!!
I knew these rims would look perfect on a 350Z or G35C. You have just proven it Topic! Might I say AWESOME RIMS!
I should be receiving mine in Mid~late Sept. THey are being shipped to the Japanese shipping house next week then on a container the week after.
So you needed 2mm spacers for your fronts? I ordered 19x9.5 +19A for my fronts, hopefully I should have no problems with my Brembos also.
I'm going to save these pics on my comp if you don't mind =)
Old Aug 31, 2003 | 06:10 PM
HXS's Avatar
HXS
yeah, for 18s, they look huge!!!
MORE PICS, MORE PICS, MORE PICS!!!
Old Aug 31, 2003 | 06:51 PM
rodH's Avatar
rodH
you like that???
other than that, they look great, any pics straight on??
btw, was it hard to find those lug nuts??
Old Aug 31, 2003 | 11:51 PM
Topics II's Avatar
Topics II
the rear tire is a lil smaller than stock (245/40 vs 245/45). i didnt want to run alot of sidewall for drifting.
Topics II's Avatar
Topics II
Originally posted by RaySur350GT
YES! YES! YESSS!!
yours should fit fine. and feel free to save the pics.
Old Sep 1, 2003 | 12:20 PM
Loren04G35's Avatar
Loren04G35
I think the issue they are trying to point out is that since your tires aren't staggered, the traction control and VDC are going to have problems all the time since the rear tires are spinning slower than the fronts. As long as you leave it off all the time, you are fine. For drifting, you would have to turn them off anyways.
The other comment about 245's on a 10" rim is one that concerns me too for safety reasons. The maximum recommended rim for a 245/40 is 9.5". The maximum recommended rim for a 245/45 is a 9.0". I am doing something similar to you. I am swapping out my front 225/45's for 245/40's. Then I am using these with the stock 245/45 rears on 9" rims all around. I decided not to go to the 245/275 on 8.5"/9.5" or 9"/10" wheels because I want a more balanced car. I want the front to stop pushing all the time, but be able to change the balance either way with small throttle inputs. Over tire-ing the rear will always cause a car to push in corners. Since the tread width of the 245/40 is only 9.7", it is pretty crazy to put it on a 10" rim. The sidewall has to be forced to flex to matte the rim at the bead. This actually over stresses the belts and can cause belt separations. In addition, forcing the rim out on a wider wheel like this puts more stress on the center of the tire causing the center to wear a lot quicker. The wheels do look great, I just think if you want to keep the 10"s out back then you should swap to at least a 255 tire for safety reasons.
Old Sep 1, 2003 | 08:48 PM
joust75's Avatar
joust75
Wow, very nice! How about a full on side view?
Old Sep 2, 2003 | 10:29 PM
myinfinitig20's Avatar
myinfinitig20
how much did you get them for...looks very nice
Old Sep 3, 2003 | 09:09 AM
Topics II's Avatar
Topics II
Well these are a part of my sponsership deal. So i dont know how much they go for.
Old Sep 3, 2003 | 01:41 PM
orhanz33's Avatar
orhanz33
how big is that lip?
Old Sep 4, 2003 | 09:44 PM
Type R Boy's Avatar
Type R Boy
that looks absolutely sick. You have great taste.
