offset Gods please help me....
Old Jan 23, 2009 | 01:38 PM
  #41
scotts300's Avatar
scotts300
Originally Posted by fart_canon
Dude WTF? that's not the tire size I want, read the entire thread ****
I have read the entire thread. I read what you are considering for tire sizes and brands, etc. You saw my response on the first page? ? ? Four other people said it would rub without additional work.
I was responding to friscomgm, hence why I attached his post, saying that I agreed those horrible sizes would probably work, but the OP (you) would have posted in the stretch tire thread instead of making a new post to help with offsets.
Old Jan 23, 2009 | 01:44 PM
  #42
M3ANMACHINE's Avatar
M3ANMACHINE
I've got 19x9.5 Fronts +17 running 245/35/19's, and 19x10.5 Rears running 275/30/19's and I think it's pretty aggressive... My fenders are also Rolled. I don't get insane camber wear, but nonethless I do get camber wear.
Old Jan 23, 2009 | 01:46 PM
  #43
M3ANMACHINE
Originally Posted by abeklipse
Question: Will I need to roll my fenders on my 350z?
Wheels: Volk GT-S 19x9.5 +17 (F) & 19x19.5 +18 (R)
Tires: 255/35 (F) & 275/35 (R)
Suspension: Tien S-Techs
Answer: ????
Yes
Old Jan 23, 2009 | 02:01 PM
  #44
fart_canon's Avatar
fart_canon
beautiful z bro....what tires do you have? any more rolling shots?
Old Jan 23, 2009 | 02:58 PM
  #45
M3ANMACHINE
The fronts pictured were 245/35/19 Yokohama NES001 (or whatever they're called) but I recently swapped them out to 245/35/19 Nitto Invo's (I highly recommend) which fill out the wheel gap much better. The first picture is also before I added the 5mm spacers which put me down to a +17, so I need to get another current shot like that. The rears are 275/30/19 BFG KDW2's
Old Jan 23, 2009 | 04:13 PM
  #46
THEDUKE's Avatar
THEDUKE
The rear will not clear your rear brakes.
Old Jan 23, 2009 | 04:35 PM
  #47
fart_canon's Avatar
fart_canon
+8?
Old Jan 23, 2009 | 05:10 PM
  #48
fart_canon's Avatar
fart_canon
can you send me shots of your current set up?
Old Jan 23, 2009 | 05:25 PM
  #49
kelsey_kaye's Avatar
kelsey_kaye
Originally Posted by scotts300
Agreed that might make it 'work', but the OP should be posting elsewhere if he wants 225s for 9.5s and 245s for 10.5s: https://my350z.com/forum/wheels-and-...s-welcome.html
Stay out of thread that don't ask about track setups, please. I'm tired of reading your worthless posts in a stretched tire/aggressive setup thread.
Old Jan 23, 2009 | 05:41 PM
  #50
M3ANMACHINE
I'll take some this weekend and send them to you. Honestly, i'd just go with either +22's all the way around and just run some 5 or 10mm spacers. Or just go with +12 all the way around if you really think you want to be that aggressive
Old Jan 23, 2009 | 07:05 PM
  #51
fart_canon's Avatar
fart_canon
my gutfeeling is the +12 all around and play it safe but fack I can't get over the fact that +4 and +8 will be so facking sick looking bro.....
Old Jan 23, 2009 | 07:30 PM
  #52
M3ANMACHINE
Just go with the 12's, trust me, you'll be way happier being able to run somewhat decent camber
Old Jan 23, 2009 | 07:37 PM
  #53
fart_canon's Avatar
fart_canon
but I think even with +4/+8 with rolled or cut fenders I could pull off the -2 camber setting. I'm gonna call Rick at Status on tomorrow to confirm or at least get his opinion...
Old Jan 23, 2009 | 08:25 PM
  #54
M3ANMACHINE
I really doubt it, but good luck
Old Jan 23, 2009 | 09:40 PM
  #55
friscomgm's Avatar
friscomgm
Here is a recent thread showing pix from pretty much all angles.
https://my350z.com/forum/media-share...-mag-blue.html
Here is another thread of mine:
https://my350z.com/forum/media-share...z-finally.html
I have Volk GT-S 19x9.5 +4 / 19x10.5 +8
(NOT +17/+18). Nitto INVO 245 and 275 width tires.
I am directly answering the question: "I wanna know if i can pull off this set up without having to do "streched tires and too much neg camber"? I would like my rear tires to have meat on them but not too much meat, so having said this what do you guys think?"
To answer your question, directly, the answer is simply no, it will not work.
You have to
A) perform significant fender modification
B) run a stretched tire
C) run a lot of negative camber
to make this setup work. And as Andy mentioned earlier - your rear BBK clearance is going to be very close.
Now, if you are set on these offsets and want to run a "standard" 245 / 275 combo and only 2 degrees of negative camber, your solution is significant fender modification.
Make sure you know what you are doing here and you'll be fine. Either do it yourself or find a TRUSTWORTHY shop to take care of it for you. This isn't some roll my fenders in a half hour type job. To get them this far out you are going to have to roll/pull/cut or whatever you prefer to gain as MUCH clearance as possible without buckling the panels.
Old Jan 24, 2009 | 08:19 AM
  #56
kelsey_kaye
OP, friscomgm's post is the most relevant for this thread. I know you didn't want too much camber or a stretched look. I'm more worried about camber for tire wear, but the only way I can see it possible to not have a mild stretch or run wild camber would be to not dump the car.
Old Jan 24, 2009 | 08:55 AM
  #57
fart_canon's Avatar
fart_canon
aggreed! he has by far the most solid with proof answers unlike the other guys that were just trying to suggest based on no knowledge. thank you again....
Old Jan 24, 2009 | 08:56 AM
  #58
fart_canon's Avatar
fart_canon
You have to
gratzy!
seagrasser
Oct 11, 2015 03:27 PM
etong
Sep 10, 2015 06:14 PM
