stuck trying to get longer studs out of my hub
Old Jan 25, 2009 | 04:52 PM
Nexx's Avatar
Nexx
Default stuck trying to get longer studs out of my hub
I had 20mm spacers installed now I'm trying to back to stock. I have my rear rotors off but the ebrake assembly is blocking the longer studs from coming off. i have no idea what to do at this point. ive read that i might have to uninstall the ebrake assembly or take the whole hub assembly off. ugh, please advise.
Old Jan 25, 2009 | 11:25 PM
35oZephyR's Avatar
35oZephyR
I removed part of my rear e-brake assembly when I installed longer studs. There is probably an easier way but I wanted to get full access.
Did you try releasing the e-brake and spinning the hub until a stud is exposed from the rear?
Old Jan 25, 2009 | 11:27 PM
Nexx's Avatar
Nexx
i took apart the ebrake assembly. i dont ever want to have to do that again. such a pain. i think i screwed up the drivers side ebrake too.
Old Jan 25, 2009 | 11:29 PM
JasonZ-YA's Avatar
JasonZ-YA
did you get it fixed? yeah, u have to remove one ebrake shoe, or somewhat remove to where you can pull it back and then spin the hub to the one spot where u can pull out the long stud...
-j
EnjukuRacing
Sep 30, 2015 06:55 AM
