I bought the wrong tires, can I get away with 30 series?
Old Feb 3, 2009 | 04:45 PM
yusoslo's Avatar
yusoslo
Default I bought the wrong tires, can I get away with 30 series?
I have toyo t1r 245/275 both are 35 series.
Well I drove 1 hour to buy Mich tires that I was told where 275/35/19
when I got there they where 275/30/19 well for 120 for two mich tires I couldnt beat it.
So priority....is it gonna look bad? I am pretty sure it will have a smaller sidewall than the front 245 which will look horrible.
I have no problem selling them again and getting the proper tire.
what is your take?
I would love to see a pic of this tire mounted if anyone has it.
Old Feb 3, 2009 | 04:47 PM
Nexx's Avatar
Nexx
if you have tcs or vdc, your car will hate you. if you drive a base and can live with the tiny sidewall then keep them. i personally would sell them. for that price they will sell easy if they are new.
Old Feb 3, 2009 | 06:39 PM
Is this what you have in mind? The front tires are taller than the rear.
Old Feb 3, 2009 | 07:00 PM
yusoslo's Avatar
yusoslo
damn that sucks, well i guess they will be up for sale
Old Feb 3, 2009 | 07:04 PM
michaeljr6's Avatar
michaeljr6
yea i tried that with mine and it didn't work out to well with my vdc
Old Feb 4, 2009 | 01:53 AM
terrasmak's Avatar
What size are your front wheels, they will work just fine up there.
Old Feb 4, 2009 | 04:56 AM
yusoslo's Avatar
yusoslo
19x 9.5 + 12mm offset.
245 on it now with about 3mm clearance on fender
Old Feb 4, 2009 | 06:08 AM
quakerroatmeal's Avatar
quakerroatmeal
I wouldn't do it either, it makes the rear tire have really small sidewalls, leaving a big gap.
Old Feb 4, 2009 | 09:34 AM
350z-Jim's Avatar
350z-Jim
The 30 series tires are cheaper than 35 which is why most ebay rim setups have 30 series tires on them to reduce the cost. 35 series sidewall in the exact same tire size is about 40 bux more a tire for some reason, probably production numbers or something. Either way on anything but a base they wont work. You must maintain the ratio difference between front and rear to keep the vdc from freaking out.
Old Feb 4, 2009 | 09:50 AM
yusoslo's Avatar
yusoslo
they are up for sale in the Mid-A marketplace. $120 and they are yours!
Thanks for the help I will just get the proper tire
Old Feb 4, 2009 | 10:01 AM
cracka350z's Avatar
cracka350z
i have a 30 series tire in the back and 35 in the front...that was my fault for not paying attention but the tires i went with actually look more like a 35 series. (i have 20 x 8.5/10.5) my vdc doesnt go nuts...maybe its cuz i have the 20 in wheels lol
Old Feb 4, 2009 | 12:08 PM
redlude97's Avatar
redlude97
your front tire is too large now, not your rear most likely
Old Feb 5, 2009 | 05:36 PM
dada's Avatar
dada
Hey I just got a pair for 20 rims from discount tire, they advised 275/30/20 for the rear and 245/30/20 for the front with 20X9.5 and 20X8.5, are they wrong? I asked the techie why we arent using 35 tall-he said no, you wouldnt want a tall tire, with that spec he said the rolling diameter they are suggesting is perfect. I wasnt sure so I checked tirerack, when you custom look at 20' they suggest this exact tire spec, am I missing something?
Help I will return if they are wrong since I havent received shipment yet
Old Feb 6, 2009 | 05:28 AM
yusoslo's Avatar
yusoslo
you should be fine.
I was going to run 245/35 275/30 that would throw things off
you should be fine.
You can use a tire calculator to find out the % difference between front and rear and search around but for the Z it should be a ~3% difference obviously having the rear larger
Old Feb 6, 2009 | 05:30 AM
dada's Avatar
dada
thanks that was a relief
Old Feb 6, 2009 | 07:13 AM
terrasmak's Avatar
Were talking about 19's here , not 20's. The 30's you asked about are the proper size for 20's.
Old Feb 6, 2009 | 07:27 AM
dada's Avatar
dada
yes thanks
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
