nail in rear tire
Old Feb 9, 2009 | 07:40 AM
meatwad321's Avatar
meatwad321
Default nail in rear tire
i have a nail in the rear tire but so far no air is comeing out of the tire, can you put patch or a plug on the tires or do you have to buy new tires... the nail has been in there for about 3 days now.
2008 350z enthusiast (stock)
Old Feb 9, 2009 | 07:54 AM
You have to buy new tires.
Old Feb 9, 2009 | 07:56 AM
Dblock55's Avatar
Dblock55
a plug is a good short solution, but you should get it patched up and youll be fine.... new tires are not necessary
Old Feb 9, 2009 | 08:07 AM
PerfZ's Avatar
PerfZ
All 4? "Cause you know you want them all to be exactly identical in terms of tread wear or your VDC won't work correctly, right?
Old Feb 9, 2009 | 08:15 AM
kecclest's Avatar
kecclest
Just get it patched. Cheap and quick to do.
Old Feb 9, 2009 | 08:28 AM
Not really. I just like new tires.
Old Feb 9, 2009 | 08:38 AM
terrasmak's Avatar
Patch it
Old Feb 9, 2009 | 08:47 AM
Motionblurrr's Avatar
Motionblurrr
where exactly did the nail hit?
Old Feb 9, 2009 | 10:29 AM
meatwad321's Avatar
meatwad321
Old Feb 9, 2009 | 10:35 AM
Entaille's Avatar
Entaille
if it hits the sidewall or close to it you cannot get it patched. you really thought that was the best angle for the picture?
Old Feb 9, 2009 | 01:26 PM
meatwad321's Avatar
meatwad321
sooooooo i would need a new tire
Old Feb 9, 2009 | 01:56 PM
quakerroatmeal's Avatar
quakerroatmeal
It all depends..Either take it to the dealer your car is most likely under warranty (I"m guessing since it's an 08) or to Discount tire, they'll be able to tell you off the spot if it's fixable or not. If your car is still under warranty and under 1 year I believe you have tire hazard warranty. At least my moms toyota did.
Old Feb 9, 2009 | 02:13 PM
Spork's Avatar
Spork
Good thing stock-sized tires are cheap.
Old Feb 9, 2009 | 02:23 PM
quakerroatmeal
Stock size tires run cheap, but the stock tire brands don't. Unless you like mix-matching brands and treads.
