6th miniture bolt?
Old Sep 11, 2003 | 07:33 AM
shimz350z's Avatar
shimz350z
Default 6th miniture bolt?
this morning I started to take of my stock rims and put on some volks...then as I tried to fit the new rims their was a little 6th miniture bolt in the way. If i take the little bolt off it fits the five lugs perfectly...what is it for? is it irrelevent because the rear tires also had the sixth hole plugged. Am I making sense? Tried searching for the answer*apologize for the repeats*
touring vin #15630
4700 miles(early july-daily driver)
only problems
-driverside clicking from the windows instead of one click it clicks 2-3xs but not a bother.( don't consider it a problem unless it keeps clicking constantly-which it doesn't)
-slight window grease(passenger) but my absorber cleans it away
-no tread wear
other then that perfect!
Old Sep 11, 2003 | 07:38 AM
little_rod's Avatar
little_rod
Remove it, it is to make sure that you don't rotate the tires from front to rear.
Old Sep 11, 2003 | 09:02 AM
shimz350z's Avatar
shimz350z
Default thanX that was QUick
appreciate little rod...i'll post pics soon.=)
AbrasiveRaysive
Sep 20, 2021 02:29 PM
wanderingstuden
Jan 28, 2016 07:03 PM
