Lady needs some wheel help!
Old Mar 15, 2009 | 11:21 AM
krisyloo's Avatar
krisyloo
Default Lady needs some wheel help!
i have the falken koblenz black wheels from a previous car...they are 18x8 with a 35mm offset...i want to stagger the rears as big as i can
19" x 10.5" 30mmoffset
19" x 10.5" 10mm offset
19" x 8.5 35mm offset
19" x 8.5 25mm offset
ive searched and searched, but havent found anything, called places, they dont call back. i have cash in hand and wanna get these things on but dont know what i can go with! help!
Old Mar 15, 2009 | 11:23 AM
krisyloo's Avatar
krisyloo
do not want to roll fenders either!
Old Mar 15, 2009 | 11:26 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
In4LegHump and 1000 replies of guy's "just wanting to help out"
Old Mar 15, 2009 | 11:27 AM
jduet's Avatar
jduet
You should be able to fit everything except possibly the 10.5 +30 depending on your suspension without having to roll. Camber would be your friend in this instance...
Old Mar 15, 2009 | 11:28 AM
krisyloo's Avatar
krisyloo
everything on the car is stock as of now...04 touring model
Old Mar 15, 2009 | 11:32 AM
jduet's Avatar
jduet
Unless your a fan of stretched look, I'd go with the 10.5 +10. You can add spacers if you want a more aggressive look.
Old Mar 15, 2009 | 11:37 AM
krisyloo's Avatar
krisyloo
thanks! yea i'd rather have the option to throw on spacers than to buy them and have them be pushed out too far already, i wanted the biggest lip i could get and thats the 10.5.
Old Mar 15, 2009 | 12:02 PM
got556's Avatar
got556
lol wut
+30 on a 10.5 wheel will allow her to run a nice meaty tire if she doesn't want stretch. a 295/30 will fit perfect and a 305 will w/ just a little bit of negative camber dialed in.
+10 10.5 is pretty damn aggressive and will stick out if you're not lowered....take this from experience. The more aggressive the offset, the stupider it will look on stock suspension. And then once you start lowering...the more aggressive the offset, the more camber you'll have to run along w/ skinnier tires and that stretched look. 19X8 w/ a +25 in the front will be pretty tucked in.
Unless you plan on lowering the car I'd stick w/ the 19X10.5 in the rear w/ the +30 and you can always space it out later. Or you can just throw a wide tire on there and your rears will be sitting flush as is.
ETA: You say you want the biggest lip you can get....well a +10 will give you a substantially larger lip that a +30....
ETA2: Holy **** I just looked these wheels up....if 1010tires is correct in their weights....these things weight 38 lbs!?!?!?!?!! Sell the wheels and buy some Enkei, AME, Volks, Works, 5Zigen, etc. And I thought mid to upper 20's was heavy in weight....wow
Old Mar 15, 2009 | 12:04 PM
jduet's Avatar
jduet
Originally Posted by got556
lol wut
Lol, thanks for correcting me, I had my offsets mixed up. Long day I guess
Old Mar 15, 2009 | 12:11 PM
got556's Avatar
got556
^ No problem
Old Mar 15, 2009 | 12:22 PM
Question
Confused. You intend to keep the 18x8 wheels in front, and find the same brand wheel different size for the rear?
Old Mar 15, 2009 | 12:23 PM
got556's Avatar
got556
I'm a bit confused by this also...
Old Mar 16, 2009 | 09:45 AM
scotts300's Avatar
scotts300
19" x 10.5" 30mm offset is perfect. Good tire size, no rolling, nice lip - now go.
Old Mar 16, 2009 | 11:24 AM
O_SO_ICY_Z's Avatar
O_SO_ICY_Z
if your on stock suspension you won't have to roll your fenders anyway. but if you do plan on dropping it I would suggest a +25 to +30. If you do go with the plus 30 get the widest tire possible so it doesn't look sunk.
Old Mar 16, 2009 | 04:52 PM
Sergio8A's Avatar
Sergio8A
pics?..........
of yourself ?
Old May 31, 2009 | 08:29 AM
How did the 19" x 10.5" wheels work out?
Old May 31, 2009 | 03:43 PM
Spike100's Avatar
Spike100
Huh? You didn’t receive the memo?
She is still running the 18 x 8” wheels. Why do you ask?
--Spike
Old Jun 1, 2009 | 10:44 AM
scotts300's Avatar
scotts300
19x10.5 +30 is quite perfect, actually.
Old Jun 1, 2009 | 10:59 AM
zerafian's Avatar
zerafian
If these choices are all you have.
with -2.5 camber (rolled fenders if you have a drop)
19" x 10.5 30mm offset
with stock specs and no drop( wont need to roll fenders)
Old Jun 1, 2009 | 02:09 PM
Nick-VTR's Avatar
Nick-VTR
