any effects if i switch to 275/30/19 instead of 275/35/19?
Old Mar 21, 2009 | 04:25 PM
diablo1356's Avatar
diablo1356
Default any effects if i switch to 275/30/19 instead of 275/35/19?
just like the title states...is there any detrimental effect if i switch?
Old Mar 21, 2009 | 05:37 PM
stradaONE8's Avatar
stradaONE8
275/35 has a diameter of 26.6in and 275/30 is 25.5 which is more than an inch off = NO NO.
My coupe came with OEM 19s which are 245/40 out back. 275/35 or 285/35 are both essentially near perfect matches for that size.
When you run a 275/30 your speedometer will be off by more than 4%, almost 5%. This will throw off your VDC and your odometer pretty severely. 30 spec tires can be run with 295 or 305, anything below that is far too small a tire for the original calibration.
As always check http://www.miata.net/garage/tirecalc.html
Put in your OEM size, put in a size to check, try to keep it less than an inch difference in diameter or less than 3% difference in speedo effects. I personally like staying as close to OEM rolling size as possible (1-2% at most), but thats just me.
Old Mar 21, 2009 | 06:22 PM
r_seng's Avatar
r_seng
you have a long way of just saying 'yes'
Old Mar 21, 2009 | 06:49 PM
Ed Hardy's Avatar
Ed Hardy
It will throw off your speedo/odo, and may cause some VDC issues too.
Old Mar 21, 2009 | 07:27 PM
ChrisSlicks's Avatar
ChrisSlicks
Look at the specific diameters for the tires you are looking at, they very greatly between manufacturers.
Old Mar 21, 2009 | 08:54 PM
Newbie question. Not befitting for a 3 year member.
Old Mar 21, 2009 | 08:59 PM
stradaONE8's Avatar
stradaONE8
trying to be helpful and explain WHY it's detrimental so he might be able to answer the same type of question himself without creating a thread for it.
Sorry about that, if I would have known it would have bothered you so much, I'd have just put the letter Y to save you some trouble of actually having to read the word yes...thanks for your input though!
You have a very brief way of contributing nothing useful to a thread.
Old Mar 22, 2009 | 11:12 AM
zman600's Avatar
zman600
^lol
yes but i have 295/30/19. its good. i put both rims (the other was stock) and tires next to eachother and they were the same height. and ive seen the 275/30 and they were a small 'bit' off. but not anuf to mess anything up i think
lapham3
Oct 7, 2022 03:15 PM
Paul.
Oct 16, 2015 07:34 PM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
