wheel spacer help
Old Apr 4, 2009 | 06:35 AM
home13oy75's Avatar
home13oy75
Default wheel spacer help
I ended up having cross threaded wheel studs on both rears wheels after trying to run a 10 mm spacer. Since I am going to replace all the rear wheel studs, do you think I should just purchase extended wheel studs and run the 10 mm spacer? Seems like that's basically a version 1 ichiba wheel spacer kit. Or should I just replace the bad studs with OEM nissan and purchase a wheel spacer kit with the studs on them like the ichiba version 2 kit.
Old Apr 4, 2009 | 07:12 AM
Z04's Avatar
Z04
please see the sticky at the top of the page
Obadabot
Jun 18, 2023 11:31 PM
