clearance question
Old Apr 7, 2009 | 11:03 PM
PowaHouseAlex's Avatar
PowaHouseAlex
Default clearance question
going to pick up some ame tomorrow
size are as as fallow
18x10.00 all around 10+offsett all around
im sure the rear will be fine but im concerned about the front being to wide
my car is also equiped with brembos i will be runing 245 40 18 in the front and 265 35 18 in the rear
will my fenders in the front need to be rolled?spacers?any info or feedback will be appreciated
Old Apr 8, 2009 | 07:11 AM
PowaHouseAlex
answers
Old Apr 8, 2009 | 07:58 AM
scotts300's Avatar
scotts300
245 is way undersized for a 10" wheel. The "stretch" may make the front work. Why would you want to put spacers on?
Ask the stretch tire boys here: https://my350z.com/forum/wheels-and-...s-welcome.html
Old Apr 8, 2009 | 08:36 AM
terrasmak's Avatar
Rear tires are shorter than the front tires, back to the drawing board.
I could post my recomendations, but i'll let you do a little ground work.
Hint , rears need to be a little taller than the fronts 1/4 to 3/4 inch works great
Old Apr 10, 2009 | 08:22 AM
Thermal1's Avatar
Thermal1
The front size you have would be fine, but you need to have 265/40s in the back.
This site is a good resource:
http://www.1010tires.com/TireSizeCalculator.asp
Old Apr 10, 2009 | 03:27 PM
A 245 mm tire will be pretty cool on a 10 inch wheel.
Old Apr 10, 2009 | 03:47 PM
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
I hope you can tell that david is being sarcastic.
If you want the 35 series in the back then you should run a 35 up front. If I were running that wheel setup I would likely run a 255-265/35 up front and 275-285/35 rear. The brand makes a difference as well since they all run a little different.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
