My New Volks hit my aches :(
Old Apr 11, 2009 | 05:20 AM
Colin_S's Avatar
Colin_S
Unhappy My New Volks hit my aches :(
Just went to fit my new 19" TE37s and the back don't fit, my arches were sitting right on the tyres They are 10.5 ET22
Trying to find someone to roll my arches just now.
Old Apr 11, 2009 | 05:59 AM
sry110's Avatar
sry110
Yup same thing happened to me. 10.5 +22 offset with 285/35/19's.
Old Apr 11, 2009 | 06:27 AM
Aches are fenders right?
Old Apr 11, 2009 | 08:00 AM
angelzhope720's Avatar
angelzhope720
hmmm my 295's fit just fine on my te's with same offset
Old Apr 11, 2009 | 08:08 AM
Thermal1's Avatar
Thermal1
Roll you fenders and/or add a little camber... Its not the end of the world
Old Apr 11, 2009 | 08:33 AM
Jason333's Avatar
Jason333
hi
I had +22 LE's fenders non rolled and +12 te's fenders rolled rolled. Both had a 295 that was actually like a 285. On the +22 I ran -1.5 camber and on the +12 i ran -2.
Hope that helps
Old Apr 11, 2009 | 09:33 AM
HATED1's Avatar
HATED1
run some neg camber and you should be good.
Old Apr 11, 2009 | 09:34 AM
Colin_S's Avatar
Colin_S
Arches are fenders yea, it's a UK thing.
Mine is pretty low, might clear if it was higher but not doing that, just going to get the 'fenders' rolled.
My 275/35 PS2s sit right on the lip, i pulled the camber right in and it was like 45 deg before it cleared. , bit of a disappointment when i thought i'd have them on today.
Old Apr 11, 2009 | 11:23 AM
datsunHEAD's Avatar
datsunHEAD
lets see the damage
Old Apr 11, 2009 | 11:26 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Arches? I started picturing the McDonald's sign. Just roll the fenders and run some more negative camber if necessary.
Jason333's Avatar
Jason333
hi
Something seems wrong. +22 with a 275 is not anywhere near a problem on a lot of slammed cars around the forums. I have only ever seen one person on here say that +22 is a problem.
Old Apr 11, 2009 | 12:06 PM
Colin_S's Avatar
Colin_S
That's what i thought, and was quite surprised but the lip sat right on the tyres.
Don't have any pics as i had to take them straight off.
Old Apr 11, 2009 | 01:24 PM
dohc350z's Avatar
dohc350z
Question
hmmm, TE37 here 10.5 +22mm with 295 in the back fit perfect...oh and the car is sitting on Eibach pro kit...Something's wrong with your setup... any pics ?
dohc350z
Old Apr 11, 2009 | 04:10 PM
drsifu's Avatar
drsifu
295 on a Michelin is different than 295 on a Bridgestone is different than a 295 on Toyos
Old Apr 11, 2009 | 07:57 PM
zerafian's Avatar
zerafian
set your camber to -2 and youll be fine...roll those fenders anyways just for extra assurance.
Old Apr 11, 2009 | 10:36 PM
aloh's Avatar
aloh
If you're lowered alot, then just add camber like everyone is suggesting. This isnt exactly an aggressive fit. Easy fix!
Old Apr 12, 2009 | 12:06 AM
ekidd's Avatar
ekidd
I had the same problems with my TA TE's with 275's in the rear. My rear coilovers were down all the way so yeah. Just do a mild roll and youll be fine.
Old Apr 12, 2009 | 10:07 AM
O_SO_ICY_Z's Avatar
O_SO_ICY_Z
Originally Posted by datsunHEAD
lets see the damage
+1000
Old Apr 12, 2009 | 03:33 PM
04zee's Avatar
04zee
Old Apr 13, 2009 | 04:14 AM
Colin_S's Avatar
Colin_S
I had to pull the camber way in past -2.0 for clearance so i'll just roll the arches and set it up with about -1.5 which i think should clear.
My tein flex are all the way down at the back with the rubber mounts also cut.
