New Wheels make the car shake?
Old Apr 19, 2009 | 10:52 AM
VBoi88's Avatar
VBoi88
Default New Wheels make the car shake?
Ok, so i use to have an 18x8 rims with 245/45/18 tires on my 2005 350z, i just bought new rims for my car, it is 18x9.5 with 264/40/18 tires on it. Everytimes when i speed 95mph or more on the new rims the car start to shake and it will get worse if i go any faster, ( i rarely go that fast, just to test out the new rims). So then i put my OEM rims back on again, and speed it at 95+ the car is running fine. So whats the deal with my new rims? because of the rims size? lug nut? tires? etc...?
Old Apr 19, 2009 | 11:02 AM
Spork's Avatar
Spork
First, slow down.
Second, were they balanced?
If they weren't... get them balanced.
If they were... get them balanced again.
Old Apr 19, 2009 | 11:03 AM
Steve-O Z33's Avatar
Steve-O Z33
Whoever balanced them sucked at it. Go to a different wheel/tire shop and have the wheels speed balanced. My fiance' has an audi that 2 shops failed to balance correctly. I took it to a shop that I heard good things about and no more vibration.
Check your tread as well. If it's wearing badly, it could be an alignment/uneven wear issue. Most likely, it's the balance.
Old Apr 19, 2009 | 11:17 AM
Jay'Z's Avatar
Jay'Z
+1 on balance.. The other thing make sure you have hubcentric rings on.....
Old Apr 19, 2009 | 11:45 AM
huyrua's Avatar
huyrua
That's what you're missing.
Old Apr 19, 2009 | 11:48 AM
aRYip's Avatar
aRYip
You need a balance...
Old Apr 19, 2009 | 11:49 AM
VBoi88's Avatar
VBoi88
yeah, i think i will try to get it balance again, and if it doesnt help guess i will go get a hubcentric rings, but where and how much does the rings cost?
Old Apr 19, 2009 | 01:29 PM
cheshirecat79's Avatar
cheshirecat79
It's the lack of hubcentric rings. They aren't an option if you want the car to drive correctly.
Old Apr 19, 2009 | 02:10 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
just ditch the 264/40/18 tires and get 265/40/18
Old Apr 19, 2009 | 02:27 PM
quakerroatmeal's Avatar
quakerroatmeal
I have extras you can have I'm in the DFW Metroplex area as well. But if not Discount Tire actually carry's them for like 15-20 dollars or something for a set of 4.
I had the same problem, they were from the hubcentric rings missing.
Old Apr 19, 2009 | 02:30 PM
Nexx's Avatar
Nexx
has anyone mentioned hubcentric rings?
Old Apr 19, 2009 | 02:32 PM
Chromex319's Avatar
Chromex319
My hubcentric rings cost me $50 bucks a pop... what gives?
Old Apr 19, 2009 | 02:41 PM
terrasmak's Avatar
I got mine free at my local discount. Normally they charge $10 or $20
Old Apr 19, 2009 | 05:01 PM
Ed Hardy's Avatar
Ed Hardy
Sounds like they need to be balanced. Hubcentric rings are a good idea too, but not absolutely necessary. Get them balanced first and see how that goes.
Old Apr 19, 2009 | 05:16 PM
davids's Avatar
davids
F U StuLax18
if they are new wheels, you most likely have the rings. So my hunch is balance - which i have a problem with as well.
Old Apr 19, 2009 | 05:27 PM
quakerroatmeal
50$ a piece? I have no idea where you are getting your 24k gold hubcentric rings from. But even the nice one from z1 auto (aluminum blue hubcentric rings) are 35$ for a set of 4. At discount tire they carry plastic ones for 10$-20$ for a bag of 4. No way in hell they should be costing 50$ a pop though.
Some say you don't need them if you put on the wheel correctly, which I did. I still needed the hubcentric rings. Most wheels don't come with them, sometimes they do though.
Old Apr 19, 2009 | 06:26 PM
WhiskeyHotel's Avatar
WhiskeyHotel
Yea, you can get the plastic ones off of Ebay for 10-12 bucks shipped.
Old Apr 19, 2009 | 07:02 PM
xedes's Avatar
xedes
Are they brand new wheels? If it's not the hub rings and the balance is good, it might be one of the wheels themselves. I put wheels on my truck and had the same issue, so I took it back to the shop and the balance was fine but the wheel itself was not right from the factory. Turns out there was a small gap between the wheel and the hub when all of the lugs were tightened. The manufacturer sent me a new wheel and I never had another problem.
Old Apr 19, 2009 | 07:22 PM
I have a similar problem at 130 MPH.
Old Apr 20, 2009 | 06:42 AM
davids's Avatar
davids
F U StuLax18
David that sounds like a minor bend in the wheel. You should get that fixed.
