TPS question
Old May 2, 2009 | 08:43 PM
Staisman's Avatar
Staisman
Default TPS question
I bought wheels OEM with TPS on it but it doesn't work. My computer doesn't show any tires pressure. Where is a problem ?
Old May 2, 2009 | 09:02 PM
xpertool's Avatar
xpertool
TPS doesn't show you actual tire pressure #
its just there to warn you if your pressure is below critical point.
Little warning sign will light up if your tire pressure is below 30psi.
Old May 2, 2009 | 09:07 PM
Chromex319's Avatar
Chromex319
I'm guessing your ride isn't 07+ if so your new TPS wheels if they are relatively newer aren't compatible with your vehicle. 07+ don't read tire pressure.
Old May 2, 2009 | 09:30 PM
kacz07's Avatar
kacz07
Did you get the memo on the TPS reports?
Old May 3, 2009 | 02:09 PM
Staisman's Avatar
Staisman
I have 2003 Touring Edition, and I have a TP monitor but my old wheels doesn't had TPS. So I bought new wheels with a TPS but it still doesn't work (.
2 Kacz07 - What u mean memo on the TPS reports?
Old May 3, 2009 | 03:38 PM
DavesZ#3's Avatar
DavesZ#3
Start here....
https://my350z.com/forum/wheels-and-...-tps-tpms.html
... all will be revealed.
Old May 3, 2009 | 04:24 PM
Staisman's Avatar
Staisman
THX very much, so I have to reprogram my sensors now. Do anybody knows how much it is cost ?
Old May 3, 2009 | 04:29 PM
DavesZ#3's Avatar
DavesZ#3
Cost varies. Some dealers will only charge you $50. Other will try to charge you $150. It takes less than ½ hour to do so $50-$75 is reasonable.
Old May 3, 2009 | 05:07 PM
MikeC350z's Avatar
MikeC350z
Default LOL
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
