Need Help with Performance wheel specs
Old May 4, 2009 | 08:21 AM
CaliSilvZ's Avatar
CaliSilvZ
Default Need Help with Performance wheel specs
Hey All,
I tried to search but it came up with pretty useless info.
Just wanted to know if the wheel specs of the Performance model is 18x8/18x8.5?
I want to run a square setup instead of staggered, would i be able to fit 245/45/18 all around?
Thanks.
Old May 4, 2009 | 09:00 AM
terrasmak's Avatar
245/40front and 245/45 rear will bring you to a square setup while keeping TCS and your ABS system happy. If you have the 06 or newer is the 8 front 8.5 rear combo , the older car has 8's front and rear
Old May 4, 2009 | 03:06 PM
CaliSilvZ's Avatar
CaliSilvZ
aww okay thanks for your help
Old May 9, 2009 | 05:51 PM
CaliSilvZ's Avatar
CaliSilvZ
I have another question... would 245/45/18 all around work? or 235/45/18 all around?
Old May 9, 2009 | 09:45 PM
terrasmak's Avatar
your car needs the stagger in tire height for proper ABS TCS etc etc. It will work , but it wont be optimal. My car and a bunch of others also seem to get really twitchy at freeway speed (side to side ) in a straight line.
I don't suggest doing it unless it is for comp use only.
Old May 10, 2009 | 12:52 AM
CaliSilvZ's Avatar
CaliSilvZ
Thank you terrasmak i'll stick with 225/45 then
