Tire howling fronts only!!! HELP!
Hey all
So i was checking my tires today to see how much tread i have left on the tire and it seems like a decent amount.
But from 0-30 or 30 and below braking, i would experience loud howling noise from the front and its getting rather annoying. I thought at first i was pretty low on tread and needed to get new tires, but after looking at it today it is not even near the wear bars.
I also checked the inside of the tire and it looks to be fine no out of normal wear indication of camber or what not.
I have a 03 performance no suspension mod, running re040 factory tires.
I will take pictures tonight when i get home
But is it just the tires it self is that loud?
Any help will be appreciated.
Hey all
Check out this thread... https://my350z.com/forum/maintenance...ering-fyi.html
Note that the alignment won't get rid of the growl - it only prevents it from getting worse or starting.
The tires are already feathered and that's what's causing the noise. By flipping them, the inner tread block (where the feathering occurs) becomes the outer block and the new inner block is smooth again.
