just a heads up on michelins
Old May 16, 2009 | 01:29 AM
Allen331's Avatar
Allen331
Spork, Re050as are actually wider than most other tires in the same size.. at least the Runflat versions are.
Old May 16, 2009 | 05:30 AM
Kwame's Avatar
Kwame
They are also slightly on the heavy side too, but a great performing and looking tire nonetheless.
Old May 16, 2009 | 07:51 AM
militia's Avatar
militia
Originally Posted by Motormouth
this is seriously a thread? really?
im sharing first hand experiences, providing pictures concerning tire fitment..
I dont see what the problem is.
Old May 16, 2009 | 12:07 PM
Sensi09's Avatar
Sensi09
Works Concepts
Originally Posted by Spork
I have 275 width RE050A PP's on the rear, and they seem narrow as well.
I had a 275 RE050A PP and they really didn't seem much wider than the stock 265 RE050A. After seeing them mounted on a 10" wheel, I wished I went with 285s.
No hard data, but I do believe the bridgestone RE-11s run rather wide in comparison to the RE050As.
To the original poster, I think this has more to do with the sidewall than anything. Oh a sidewall that is less rounded should be better for performance, assuming the compound is the same.
Old May 16, 2009 | 12:19 PM
Sensi09's Avatar
Sensi09
Works Concepts
Originally Posted by Kwame@z1
As it has been already stated, each and every tire is different. However, generally speaking PS2s are considered to run wider than most tires in the same size. For instance in these pictures the tire on the right is the Pirelli P zero in a 305/30-19 on the left is a Michelin PS2 size 295/30-19 both on 19X11.5 inch rims from CCW. As you can see the PS2s are much wider.
Wow, that seems like a huge difference.
I was curious so I looked up the section widths.
-Pirelli p-zero 305/30/19 has a section width of 12"
-Michelin PS2 295/30/19 has a section width of 11.9"
But section width of the tire is dependent on the rim in which it is mounted. When you add an extra .5" in rim width that adds roughly .2" in section width to the tire.
Again the p-zero has a section width of 12" when measured on a 11" rim. The 11.5 inch rim should yield a 12.2" section width for the p-zero.
The 295 PS2 has a 11.9" section width when measured on a 10.5" rim. Mounting the PS2 on a 11.5" rim will add .4" of section width to yield 12.3" section width for the PS2.
Kinda random, but whatever....
Pleask
Dec 21, 2021 03:17 PM
