TSW Volcano Rims -- Help!!
Old May 17, 2009 | 12:55 AM
kamy0587's Avatar
kamy0587
Default TSW Volcano Rims -- Help!!
Ok, so i just bought a set of TSW Volcano Wheels in hyperblack with tires. there 19x8 in the front and 19x9.5 in the rear. 245/35r19 in the front, and 275/35r19 in the rear. So i checked it on a tire calculator it seems to be a perfect fit, its less then 0.5% difference. Does anyone know what the offset is for these rims? I wasnt able to find it. And would these rims raise my car or stick out, stick in? I just want to make sure if they rims would fit my car correctly...Eventhough i should of done this b4 i bought them, but i got them on Ebay and didnt have enough time to research. i have stock springs. Also if anyone has pictures of a Z with these wheels that would be GREAT! Thanks!!
Old May 17, 2009 | 02:58 AM
duro78's Avatar
duro78
almost all wheels are sold with an option of different offsets. if you have the wheels already you can actually measure the offset..hopefully they are somewhat close to the right offsets because if you bought them just because of the bolt pattern matches they can still be wayyy off.
Old May 17, 2009 | 07:02 AM
cheshirecat79's Avatar
cheshirecat79
Look on the back of the wheels somewhere for an offset. Usually it's a number.
Old May 17, 2009 | 07:28 AM
Unless the offset is stamped on the wheel there is no way to tell. Just put them on the car. Use caution tightened the lug nuts. They may not clear the brake calliper. Or you may be pressing the tire against a suspension component.
Old May 17, 2009 | 11:26 AM
kamy0587's Avatar
kamy0587
I havent received the rims yet. But i did check on a couple websites and it was compatible with the 350z with brembo brakes. And that person that sold it to me said it was for a 350z or g35 and most other RWD japanese cars.
Old May 17, 2009 | 11:27 AM
kamy0587's Avatar
kamy0587
and what would be a good offset for these wheels? 25-35?
Old May 17, 2009 | 11:28 AM
Chromex319's Avatar
Chromex319
I sense buyers remorse. Keep us updated.
Old May 17, 2009 | 12:45 PM
It will be OK. Many wheel retailers will tell you if a wheel fits but not the offset. They just do a offset comparison with the OEM wheel and give you a conservative fit.
Old May 17, 2009 | 01:04 PM
Rowlett's Avatar
Rowlett
Are these the wheels, these are +42 & +40...
Old May 17, 2009 | 01:12 PM
kamy0587's Avatar
kamy0587
No those pics you posted are 19x8 all around. ill post the ebay link----
http://cgi.ebay.com/ebaymotors/ws/eB...lenotsupported
Old May 17, 2009 | 01:24 PM
Rowlett's Avatar
Rowlett
hmmm, good luck hopefully they will look great on your car..
Old May 17, 2009 | 01:30 PM
kamy0587's Avatar
kamy0587
yea i hope so, i could not find a single Z with these rims on it...so i guess ill have no idea what it will look like till i put them on
Old May 17, 2009 | 01:31 PM
teh215's Avatar
teh215
My guess is they will be a bit tucked..just guessing. Nothing some spacers can't fix.
Old May 17, 2009 | 01:44 PM
kamy0587's Avatar
kamy0587
ya i should of researched more before i bought them, but i got them for so god damn cheap..so i dont have any regrets
Old May 17, 2009 | 02:43 PM
zerafian's Avatar
zerafian
why with such bad offset would they advertise those for specifically G's and Z's
Post some pics when their mounted. But as teh215 stated spacers will do the trick...30mm all around :/
Old May 17, 2009 | 03:08 PM
kamy0587's Avatar
kamy0587
the seller didnt say what the offset was...thats what im trying to figure out. the pictures that Rowlet posted are the wrong rims. i attached a ebay link
Old May 17, 2009 | 06:22 PM
350ZToeRing's Avatar
350ZToeRing
This is weird. I checked TSW's website and they only list the Volcano's in 15"-17". So maybe the pictures that Rowlet posted ARE Volcano's and you just have the wrong name. Can YOU post a pic of them? Either way I have TSW's and the offset is stamped on the back of one of the spokes... its a small number inside of a circle. If its a 19" TSW it maaaay be +20
Old May 17, 2009 | 06:55 PM
cheshirecat79
BRAND: TSW
MODEL: Volcano
COLOR: Hyperblack (Gunmetal)
BOLT PATTERN: 5x114.3 (5x4.5)
OFFSET: +40
Just a set of wheels I found on the internet.
It looks like your offsets will most likely be pretty high. You'll need some spacers to bring them out.
Expect to get spacers in the 20-25mm range to bring them out decently. Maybe even 30mm.
Old May 17, 2009 | 09:59 PM
O_SO_ICY_Z's Avatar
O_SO_ICY_Z
^^+1 at least 20mm spacers all the way around are gonna be needed
Old May 18, 2009 | 08:04 PM
350ZToeRing
DA-YUM! 20mm spacers would suck. I wouldn't get the wheels then....
...just my
