tire set-up
Old May 18, 2009 | 10:09 AM
mikey370z's Avatar
mikey370z
Default tire set-up
I'm new to this site and my name is mikhel, and i have a red 2006 nissan 350z touring
I plan on keeping my stock rims for a while until i can get some volk te37's
but i do want to upgrade my tires. Will i be able to fit
245/40zr/18 front
255/45zr/18 rear
without any issues whatsoever with vdc or anything else with this set-up, any inputs will be greatly appreciated
Old May 18, 2009 | 11:47 AM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
The 255/45 is quite a bit taller than the 245/40's. I suspect that will cause issues. A 265/40-18 would be better with the 245's.
Old May 18, 2009 | 12:16 PM
mikey370z's Avatar
mikey370z
i made one orignally, but i put it in the wrong section, so i decided to make another one which is totally my fault man
Old May 18, 2009 | 12:22 PM
mikey370z's Avatar
mikey370z
that is true, but im gonna keep my stockers for a while, which is 8 in front and 8 .5 rear, is there anyway u can possibly come up with something that i can go with?
Old May 18, 2009 | 12:49 PM
guitman32's Avatar
guitman32
You want:
245/40/18
255/40/18
265/40/18 (if you want a beefier rear tire)
Edit: Tire size calculators are your friend:
http://www.1010tires.com/tiresizecalculator.asp
Old May 18, 2009 | 12:55 PM
mikey370z's Avatar
mikey370z
Originally Posted by guitman32
You want:
245/40/18
255/40/18
coolness, and thanks for the reply man, so ur saying that this set-up will work on the stock 2006 rims without any fender rubbing or speedo issues right?
Old May 18, 2009 | 01:08 PM
Rear tires are 33mm taller than front. I would prefer to see 10-20mm.
Old May 18, 2009 | 03:30 PM
guitman32's Avatar
guitman32
I ran the former setup (245/40, 255/40) for a good while on factory 03-05 track wheels with no issue. You definitely won't have any rubbing issues.
I'm not gonna spoon feed you (so you learn), but if you go into the tire size calculator, compare your stock sizes to the new sizes. The app will give you a speedo difference in %. This is the percentage you can expect your speedo to be off with the new setup.
Let us know if you have any more questions!
Edit: Read this to learn about VDC operation and its relation to front and rear tire diameters:
https://my350z.com/forum/wheels-and-...read-here.html
terrasmak's Avatar
245/40 front and 245/45 rear is also a great setup
Old May 18, 2009 | 04:03 PM
mikey370z's Avatar
mikey370z
ive done some research on the set-up that i want to do n if i put the 245/40/18 on the front, there is a 3.64% difference on the front tire, and reading from that one thread that u can't go over 3% or u wil cause complications with the computer... so can i get ur input on that i dont really wanna scrw up my car ya know
Old May 18, 2009 | 04:24 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
best bet is plugging the various sizes into the calculators online and you can find your ideal setup. It will also tell you how much, if any, the speedo will be off
you have no fear of rubbing, stock wheels are nowhere near the body panels
Old May 18, 2009 | 04:41 PM
guitman32's Avatar
guitman32
There are two comparisons you have to make.
1. Speedo error calculation: Compare your stock front tire size to the new front tire size (e.g. 225/45/18 vs 245/40/18):
225/45/18: Overall Diameter: 25.97 in (659.63 mm)
245/40/18: Overall Diameter: 25.71 in (653.03 mm)
Diameter Difference: 1.01%
Your new tire will be slightly smaller in diameter, therefore your speedo will read 1.01% too fast at a given speed. This has nothing to do with VDC.
2. VDC compatibility calculation: Compare your NEW tire sizes, front to rear (e.g. 245/40/18 vs. 255/40/18):
255/40/18: Overall Diameter: 26.03 in (661.16 mm)
Diameter Difference: 1.23%
Your VDC will be fine with the new setup, since the diameter difference front to rear is only 1.23%. You are correct in that you want to keep this difference less than 3%.
Hope this helps.
Old May 18, 2009 | 06:53 PM
mikey370z's Avatar
mikey370z
Hope this helps.
dude u've been really helpful n now im actually stress free
i think im gonna go with this set-up
245/40/18 front
255/40/18 rear
and im going with some toyo t1r tires
Old May 19, 2009 | 08:30 AM
guitman32's Avatar
guitman32
Glad I could help. Post pics when you have the new tires on.
Old May 19, 2009 | 09:47 AM
terrasmak's Avatar
why? just picture a stock Z with stock wheels and black things know as tires wrapped around the wheels. It will look the same as before, just a little more wheel well gap in the rear due to the shorter tire
Old May 19, 2009 | 09:51 AM
scotts300's Avatar
scotts300
245/40/18 front
255/40/18 rear
May I ask why you've decided on Toyo T1Rs?
Old May 19, 2009 | 10:58 AM
guitman32's Avatar
guitman32
Cause I like looking at pictures of peoples Zs, stock or otherwise. The value for posterity is also there...maybe someone wants to see what a 245/255 setup, on T1Rs (or whatever tire he uses), on stock wheels, looks like. Or, don't post pics at all. Either way no skin off my back.
Old May 19, 2009 | 07:14 PM
gmic350z's Avatar
gmic350z
im buying tires this week and i have same wheels.it would help me out if you posted some pics,i was looking to get these same size tires in the goodyear f1,maybe a 235 in the front.anyways if you have the time ,post some pics..
Old May 20, 2009 | 07:47 AM
mikey370z's Avatar
mikey370z
yeah i just ordered my tires, i didnt buy the toyo t1r's but i ended up buying the yokohama advan sport, got if 1000 bucks even from tire rack, i just felt really comfy with the tires since i was dealing with a rep ya know, n plus my z is at the shop getting repainted
