HELP: Need power tool to remove lugs at the track
Hey:
Can anyone recommend a tool that is cordless or runs off the cigarette lighter, that I can use at the track to quickly remove the lugnuts on my car? It takes me too long to wrench it by hand. Any suggestions are appreciated.
I dont think your gonna find anything with enough amps or torque to remove lugnuts at least one that plugs into a cig lighter. you can use a cordless drill but you would still have to tighten or loosen by hand a full turn before it can actually turn them. Me personally like to feel that there on there tight.
National Z Club President
Snap on has a tourqe gun that is cordless. My buddy has one and unless some bolts are stuck it gets everything on and off
There are a couple of other cordless tourqe guns but Im not sure of the amount of tourqe they provide nor have I used any of them.
I would still personally do one turn on and one turn off by hand with a tourqe wrench to be sure they are tourqed properly though, especially for track use.
There are a couple of other cordless tourqe guns but Im not sure of the amount of tourqe they provide nor have I used any of them. I would still personally do one turn on and one turn off by hand with a tourqe wrench to be sure they are tourqed properly though, especially for track use.
http://buy1.snapon.com/catalog/item....re&dir=catalog
there you go... 650 ft lbs of breakaway tourqe
I think that should do the trick. This new model has allot more tourqe then the old model my buddy had.
Description:
Includes impact wrench, two CTB4185 Battery Packs and CTC420 Charger in storage case.
Features:
• Super Heavy Duty motor, impact hammer and anvil.
• Powerful 48mm Heavy Duty motor with twin ball bearings.
• Thinner nose design permits easier access to fasteners.
• Oil seal keeps dirt out and lubrication for longer tool life.
• Caged brush motor triples brush life.
• Patent Pending True Flat Anvil allows sockets to easily slide on and off the anvil.
• Unique Forward/Reverse Switch.
• Patent pending battery power system includes shock absorbing terminal block.
• Dual rail, slide-on battery pack.
• Tilted battery receptacle footprint.
• Over molded cushion grip and tapered ergonomic grip.
• 3/8" Anvil available (CT4810-113).
• EU/CE - DE, ES, FR, GB, IT, NL European models.
• UL Listed in USA and Canada.
Product Specifications
Stock # CT4850HO
Name Impact Wrench, Cordless, 18 Volt, Slide-on Battery, 1/2" Drive (U.S.)
Price** $529.95
Square Drive, inches 1/2
Bolt Break Away Torque, ft. lb. (N•m) 620 (840)
Torque Output, ft. lb. (N•m) 400 (475)
Blows per Minute, BPM 2,100
Free Speed, RPM 1,900
Motor Size 48mm
Motor/Battery Voltage 18VDC
Battery Type 2.4 AHr (slide-on)
Charge Time Approx. 35 minutes
Battery CTB4185
Battery Charger CTC420
Length, inches (mm) 10.05 (253)
Height, inches (mm) 10 (254)
Width, inches (mm) 2.5 (70)
Weight, lbs. (kg) 7.9 (3.4) w/battery
Vinyl Boot CT4850BOOT
Carrying Case PB165
I think that should do the trick. This new model has allot more tourqe then the old model my buddy had. Description:
Features:
Stock # CT4850HO
Price** $529.95
Motor Size 48mm
Battery CTB4185
Carrying Case PB165
Bump back from the dead. I found this post while looking for a decent (i.e. well priced) torque wrench for the track. I spend so much time taking wheels on and off, not buying this piece of equipment is just silly.
I see that 24V Goodyear one in a few locations. It claims 200lbft of torque. Although I doubt it will get all the way there, I can only assume that it torques above the 85lbft that I torque the lugs to. Would you guys use this to put ON the lugs as well (then tighten by torque wrench)? I'm concerned about going above the recommended 80-90lbft of torque for lugs, and I don't believe that these particular cordless torque wrenches have any sort of throttle control. Thanks.
