Will these fit? i need serious help..
Old May 23, 2009 | 02:51 PM
domsaywha's Avatar
domsaywha
Default Will these fit? i need serious help..
19 wheels front is 8.5 35offset rear is 9.5 20offset
Old May 23, 2009 | 03:01 PM
cdoxp800's Avatar
cdoxp800
Yes, but the front offset (35mm) is Terrible. Try looking for something say around the 20mm offset.
Old May 23, 2009 | 03:42 PM
Fit is a functional question. If the wheels and tires run free without hitting the suspension or body, they fit. Fit like you would like is a preference question. I can answer the fit question, but not the fit as you would like question.
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old May 24, 2009 | 05:29 PM
SchismX's Avatar
SchismX
Rear is good, the front will need some spacers to sit nicely in the fenderwell
350z82
Oct 1, 2015 06:25 PM
