Official Aggressive Wheels & Fat Tires Thread
Old Aug 18, 2011 | 06:28 AM
  #2361
blue350zed's Avatar
blue350zed
Went a bit bigger than what I had before. Same wheels, larger tires in the rear.
19X9.5 +12 with 255/35's
19X10.5 +12 with 295/30's
It's gonna need a little more pulling and some slight camber adjustments after looking at it on the ground. Shouldn't be too bad though. I'll get some finished pics of it up when it's all done.
Old Aug 18, 2011 | 07:19 AM
  #2362
Waiz's Avatar
Waiz
^Nice, getting the thread back on track
Old Aug 18, 2011 | 07:29 AM
  #2363
Total D's Avatar
Total D
Originally Posted by gs400speed23
tires are 275/35/19 and 245/35/19 fronts. with + 0 front and -2 rears
What suspension setup are you running. Reason I ask is, I have 255/35F and 285/35R with +17F and -2R and mine do not look near as good as yours.
I am on Eibach pro springs but my KW Clubsports just arrived, so I hope that helps with my look.
James
Old Aug 18, 2011 | 08:55 AM
  #2364
scotts300's Avatar
scotts300
Originally Posted by Crawling_Drunk
I'm going fat tire... tired of the stretched look plus I'm aiming at 500whp, so I need more grip.
My wheels are: 18x10 +18 (all around)
-Tires
Front: Sumitomo HZR III 265/35/18 F, no spacers
Rear: Sumitomo HZR III 265/35/ 18 R, 15mm Spacers ( I think, but it sits flush)
-Replacement Tires
Front: Nitto NT-05 265/35/18 F
Rear: Nitto NT-05 285/35/18 R
Spacers: ???
The ideal set-up I was going for was:
255/40/18 F (3mm spacer)
275/40/18 R (10mm spacer)
However, I have a set of NT-05s with barely any use in my storage unit, and I see no reason why not to try them first before ordering 4 new tires >.<. I'd like to stay flush, and I know that the profile in the front tires will be very similar (tho I'm hoping the nT-05s look meatier on the front). Any spacer recommendation for rear? 10mm?
If you really want grip, dial out the rear camber to near-zero. You probably won't have room for a spacer then, and you'll maximize your contact patch.
Old Aug 18, 2011 | 09:58 AM
  #2365
Crawling_Drunk's Avatar
Crawling_Drunk
My fenders are rolled... about credit card clearance between the tire and fender right now tho. No rubbing issues.
Old Aug 18, 2011 | 10:06 AM
  #2366
scotts300's Avatar
scotts300
So that's a 265/35/18 on a net 18x10 -5 for your current set-up? At what camber?
Old Aug 18, 2011 | 05:45 PM
  #2367
Crawling_Drunk
^^ Noob comment: Don't know, I bought the car with the suspension/tires as is. I haven't really bothered to mess with it... tho now, I've been trying to learn.
Old Aug 19, 2011 | 09:55 AM
  #2368
gs400speed23's Avatar
gs400speed23
James
Im on fortune auto coilovers. these things go down pretty low. and BFG KDW has pretty fat walls compared to other brands. about 1/4 inch of the tire is inside the fender too maybe that is the difference. hope that helps sir.
Old Aug 19, 2011 | 09:59 AM
  #2369
gs400speed23
^TOTAL D this is another picture of my that i found in the internet. i think this picture is perfect for you to use as reference in terms of tire and fender fitment.
Old Aug 19, 2011 | 12:57 PM
  #2370
Total D's Avatar
Total D
gs400speed23- Appreciate it sir. My tires stick out past the fender on the rear and is the same setup you have. Yours being 275 and mine 285 should have that much a difference but again I am not on coilovers just yet.
Thanks again. NOW BACK ON WITH THE PICS!!! HAHA
Old Aug 19, 2011 | 03:17 PM
  #2371
gs400speed23
yea 285 would for sure rub for me. and also negative camber is key once you get coilovers. but not quite sure if kw can go that low..
Old Aug 19, 2011 | 07:36 PM
  #2372
AznSky's Avatar
AznSky
For everybody running 255/35/19 and 285/35/19 are you guys having any TCS/VDC issues? Based on tire calculator the difference is 3.1% (just over the recommended 3%).
Seems like it would be better to run 285/30/19 since the difference is only around 1%?
Old Aug 19, 2011 | 08:33 PM
  #2373
Waiz's Avatar
Waiz
That's pretty much the standard setup, you won't have any issues with it.
Old Aug 20, 2011 | 07:52 PM
  #2374
dkmesa350z's Avatar
dkmesa350z
so you'd rather be under the recommendation by 2 than over by .1?
255/35 285/35 is perfectly fine.
Old Aug 21, 2011 | 01:41 PM
  #2375
AznSky's Avatar
AznSky
humm.....no?
Thanks for the confirmation guys.
Old Aug 21, 2011 | 07:53 PM
  #2376
scotts300's Avatar
scotts300
You can't do that because the 285/30 is shorter than the 255/35. 285/35 is taller than the 255/35. Regardless, the 255/285/35 combo is great. We have been running on the wife's 07' for a long time now. Her 04' was a lot more sensitive to the rules than her 07' has been. I bet the programming is different.
Old Aug 21, 2011 | 08:00 PM
  #2377
brandon3434's Avatar
brandon3434
285/35/19 - Yeah, I know its mild/not really that aggressive...but works perfect for my slow car...
http://www.flickr.com/photos/stevegripp/6065871502/
Old Aug 21, 2011 | 08:28 PM
  #2378
ComeBack's Avatar
ComeBack
^^ I like!
Old Aug 21, 2011 | 09:13 PM
  #2379
Waiz's Avatar
Waiz
Brandon you tease.. more!
Old Aug 21, 2011 | 11:53 PM
  #2380
ReV2Red's Avatar
ReV2Red
I haz da turbos
That is absolute filth! I love it!
How do you like the AD08's? They seem to run a bit wider than regular 255's dont they?
