Official Aggressive Wheels & Fat Tires Thread
Old Aug 27, 2011 | 03:28 PM
  #2401
InsaneWang's Avatar
InsaneWang
^^^SICK!!
Old Aug 27, 2011 | 03:49 PM
  #2402
Waiz's Avatar
Waiz
Originally Posted by Z Professional
in about 2 weeks time I should have all that i need to post up in this thread.
275-35-19 on 9.5 fronts and 295-35-19 on 10.5 rears...
Dropped on Stance Gr+ true style coilovers.. and all the secondary mods that come with that.
To start off with +22 offset all around.. Just curious if I'll need to pull...I'm rolling it once i install everything but will i need to pull dependent upon how low i go?
No pull, just don't go retardedly low and you will be fine.
Originally Posted by sleeper400
im on tein basics, 3/8" away from maxing out the front to the lowest setting. Im running rota p45r 9.5 +20 on all four corners with a square setup of 275/40. My front camber is -3.7. When i turn, I rub =( how do you guys pull this off?? Im planning on pulling the fenders to fix this
Raise your car and your problems will go away, no reason to max out your settings..
Old Aug 27, 2011 | 09:10 PM
  #2403
Z Professional's Avatar
Z Professional
But i want to go retard low....
Old Aug 27, 2011 | 09:15 PM
  #2404
Waiz's Avatar
Waiz
lol
Then prepare for fender modifications..
Old Aug 27, 2011 | 10:01 PM
  #2405
Z Professional
So basically my car is an interlagos fire, and i'm tryin to have somewhat similar fitment to the Porsche 996 in that pic (why my tires are so huge...) but like a lil lower than that Brickyard..actually a lot lower.
But that 996 is one of my favorite cars of all time.
And that brickyard obviously isn't mine but if the owner of this car doesnt want me using this pic feel free to tell me...
Sadly though everyone i know in south florida is tryin to pull off the form over function hellaflush thing and i prefer having maximum meat to go round the turns wit grip like Spiderman...Just wish I knew someone down here to give tips on the fender modification thing.
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-flatblack996rsr.jpg   Official Aggressive Wheels & Fat Tires Thread-19blkpurpleangle.jpg
Old Aug 28, 2011 | 11:28 AM
  #2406
03threefiftyz's Avatar
03threefiftyz
Thread cleaned up...infraction issued.
Old Aug 28, 2011 | 12:32 PM
  #2407
bmccann101's Avatar
bmccann101
that 996 has cut out fenders and wide skirts like mine... its the only reason i went w a "failside" kit.. the widebody is a real widebody, but in the fenders only..
the fronts cant really go as wide as this car, but you can still fit a giant tire up front. ive heard of ppl rolling 275s in front.. dunno.
That pic is my desktop at work too haha.
if you want crazy grip, use very good tires, and make sure you spend your cash on suspension and camber gear, and spend an equally good amount on a real alignment..
Old Aug 28, 2011 | 09:11 PM
  #2408
mikex228's Avatar
mikex228
need some help, might be leaving the stretched tire world and joining yall...just wondering if anyone knows off the top of there head will 245/35/19 (1) and 275/35/19 (-3) fit without major problems..fenders are already rolled...thanks !
Old Aug 28, 2011 | 10:41 PM
  #2409
-Trav-'s Avatar
-Trav-
^ go back 3-4 pages
Old Aug 28, 2011 | 11:45 PM
  #2410
SE5spd's Avatar
SE5spd
Originally Posted by Duckeee
thread needs more pictures and less talking
isnt that Nitrouz car?
Old Aug 29, 2011 | 12:49 AM
  #2411
67ZNISMO's Avatar
67ZNISMO
yup! one of my favorites!
Old Aug 29, 2011 | 03:02 AM
  #2412
Total D's Avatar
Total D
I was running a 275/35/18 no problem on Eibach Pros. I have since switched my setup to 19s and run a 255/35 up front. Might try a 275 up front on the 19s and see what happens. My only problem right now is my rear stick to far out but thats my fault for getting -2 offset haha I still like it in a way though. Maybe once I get these KW's dialed in my stance will look a little better.
Old Sep 3, 2011 | 06:15 AM
  #2413
nismofreak1208's Avatar
nismofreak1208
ahhh, i need some help guys, i'm ordering a set of 19x10 front and 19x11 rear wheels for my Z but i can't wrap my head on the tire sizes in order to keep the VDC/TCS happy. I tried using http://www.miata.net/garage/tirecalc.html but i still don't know what i'm looking for. The tires i'd like to fit on is 305/30/19 for the REAR. But for the fronts, do I go with 265 OR 275/30-19 for the FRONT? I've seen many setups while searching on the forum, but no definite answer as to whether this keeps the system happy. I usually find the common 255/35/19, 285/35/19 answer. Thanks guys.
Old Sep 3, 2011 | 06:22 AM
  #2414
03threefiftyz
265/275 30 would be fine with a 305/30 in the rear.
Old Sep 3, 2011 | 07:49 AM
  #2415
scotts300's Avatar
scotts300
Agreed. Otherwise you have to go 255/35/19 front to keep VDC happy. I like the 275/30/19 up there.
Old Sep 3, 2011 | 04:35 PM
  #2416
nismofreak1208
Cool beans, mucho thanks everyone!
Old Sep 3, 2011 | 09:34 PM
  #2417
-Trav-'s Avatar
-Trav-
Isnt a 255/35 and 305/30 combo too small a difference for vdc?
Old Sep 5, 2011 | 06:52 AM
  #2418
scotts300's Avatar
scotts300
305/30 is ~.2" taller than the 255/35. That combo has worked for people before. I also think the 07-09s are less sensitive than the early versions. I say this based on my experience with wheels on my ladies 04' and 07'. The VDC of the 04' was much more sensitive than the current 07'.
Old Sep 5, 2011 | 07:14 AM
  #2419
Johnnyone's Avatar
Johnnyone
did u ever find the answer u was looking for? this sounds like a setup i would be interested in.
Old Sep 5, 2011 | 11:22 AM
  #2420
SoCal07HR's Avatar
SoCal07HR
Has it been two weeks yet? This setup will be badass.
