Official Aggressive Wheels & Fat Tires Thread
Old Jul 23, 2009 | 10:12 PM
  #261
TheHulk's Avatar
TheHulk
Originally Posted by scotts300
Wrong thread, Guy.
this just makes me want to say roads closed pizza boy....find another way home
Old Jul 24, 2009 | 12:04 AM
  #262
gennosuke1's Avatar
gennosuke1
im guessin that most of you who have 305 tires are F/I or else i dont really see the point unless you have a thing for beefy tires
Old Jul 24, 2009 | 06:33 AM
  #263
JZurita's Avatar
JZurita
^ Even when I was NA I'd get tire spin. Fatter tires are always functional.
Old Jul 24, 2009 | 04:21 PM
  #264
wmousawi's Avatar
wmousawi
heeey need some expert opinions over here.
i just ordered my wheels. those are the specs
Front 19x9.5 with 25 offset
Rear 19x10.5 with 22 offset
need the best tire setup. i was thinking 245/35/19 275/35/19 since no problems have been reported lol. i dont wanna go over 295 in the back so i appreciate anything from 275,285,295.. please give me full tire specs with the profile sizes also. i dont want stretched look so need a setup for those mean wide wheels.
so what do you guys think? i have an 07 350z with the vdc. need the best setup without traction problems. running stock suspension at this time. dont want spacers, i will roll the fenders if needed. thnx guys
Old Jul 24, 2009 | 05:06 PM
  #265
redlude97's Avatar
redlude97
275/30/19F 295/30/19R. Roll fenders. Done
Old Jul 24, 2009 | 10:06 PM
  #266
wmousawi's Avatar
wmousawi
wow that would be huge might do it once I get the suspension work done. but for now on stock suspension wud 255/35/19 285/35/19 look good on stock suspension and is that the correct sizes anyway? and will i need to roll fenders on that also?
Old Jul 25, 2009 | 01:23 AM
  #267
350Z_NOW's Avatar
350Z_NOW
Work Meister S1
19x9.5 +14 245/35 soon to be 265/35
19x11.5+12 285/30 soon to be 295/30
Old Jul 25, 2009 | 07:51 AM
  #268
resauto's Avatar
resauto
specs
HRE 543
19x9 -16 255 30 Conti sport
19x11 -3 315 25 Conti sport
Jp Vizage front lip (temporary till I put Gialla back on)
Ings +1 sides
Sparco Milano seats
Tanabe DF 210 ( I think....its been 5 years)
Tockico DSP9 adjustable shox
SPC front and rear camber arms. Front arms reversed for more negative camber adjustment
Old Jul 25, 2009 | 07:23 PM
  #269
blueper4mancez's Avatar
blueper4mancez
those wheels are so sick .
Old Jul 26, 2009 | 03:55 AM
  #270
quakerroatmeal's Avatar
quakerroatmeal
Dang you look pretty low resauto with nice offsets and meaty tires. Anybody on here that's actually slammed with aggressive offsets/fat tires? Seems the only way is to run stretch and run massive amounts of camber..
Old Jul 26, 2009 | 10:19 AM
  #271
resauto's Avatar
resauto
-16 and -3 with 255 and 315 slammed is not areggessive fat and low enough for you
Old Jul 26, 2009 | 11:27 AM
  #272
quakerroatmeal
Oh I never said you were lol. But I still see some actual fender gap. I don't get how you're running the setup without tearing your fenders apart from rubbing.
Old Jul 26, 2009 | 12:44 PM
  #273
chili7412's Avatar
chili7412
Just a thought, 255/35/19 = 661mm or 26" 285/35/19 = 683mm or 26" 9' that a difference of 3.3 % between the diameter of the wheels with tires, a possible issue with the VDC. 285/30/19 would be a better choice, its height is 655mm or 25" 8' that's only a .9% different from the front. I am running 265/35/19 front and 305/30/19 in the back stock susp. no rubbing. it will be dropped soon, and the fenders will have to be rolled. my ofset is +22 and i am thinking of getting +10 or +15 spacers up front.
Old Jul 26, 2009 | 01:56 PM
  #274
quakerroatmeal
What? I'm running 255/35/19 and 285/35/19 and it's perfectly fine with vdc. My friend is running 255/35/19 and 285/30/19 and he's the one with VDC issues.
When I put it in the calculator:
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
225/45-18 4.0in 13.0in 26.0in 81.6in 777 0.0%
255/35-19 3.5in 13.0in 26.0in 81.8in 775 0.2%
245/45-18 4.3in 13.3in 26.7in 83.8in 756 0.0%
285/35-19 3.9in 13.4in 26.9in 84.4in 751 0.6%
285/30-19 3.4in 12.9in 25.7in 80.8in 784 -3.6%
Old Jul 26, 2009 | 03:06 PM
  #275
chili7412's Avatar
chili7412
Smile
You are correct. On comparing those sizes to the oem fitment. The 285/35/19 is much closer diameter to oem wheels, than the 285/30/19. I was just comparing the 255/35/19 to the 285/35/19, that’s where the 3.3% difference was, and if that’s not an issue than great. And I also stated that “it might be a problem” unfortunately I am not running that set up so I could not comment on, if it will or will not have an effect on VDC 100%. Or F it, just go with 305’s this is the fat tire thread after all.:
Old Jul 26, 2009 | 10:11 PM
  #276
skaterbasist's Avatar
skaterbasist
Not hating nor dissing anyone's rides, but half of these setups belong in this thread: https://my350z.com/forum/media-share...ber-shots.html
The thread title states aggressive AND fat tires...meaning both
I think the bare minimum on a 10.5 would be 275 if you have the rightful excuse of being aggressive in terms of fitment [offsets, camber] to the point where you can't run them any fatter.
Old Jul 26, 2009 | 10:14 PM
  #277
skaterbasist
Originally Posted by resauto
specs
HRE 543
Ings +1 sides
Sparco Milano seats
Two thumbs up
Great work man!
Old Jul 27, 2009 | 08:55 PM
  #278
2k6-z33's Avatar
2k6-z33
^+1!
Old Aug 2, 2009 | 05:25 PM
  #279
Toby-22's Avatar
Toby-22
One more
Old Aug 3, 2009 | 06:26 PM
  #280
ITOzann's Avatar
ITOzann
Originally Posted by 350ZEEEEE
^^ Definitely need to lower the car more
It's lowered now..!! Pictures were taken 6 months ago.
What's the wheel's offset? 275/40/18 is a tall tire for the front (I know it's on an 18, but it's taller than a 275/35/19 tire by 0.1"). My 275/40/17 track wheels/tires barely fit in the front, and your proposed tire is 1" taller. It'll be tough.
wheel offset is 20mm.. You had a good point, at the end I ended up getting 275/35/18 for the front and 295 in the rear. Thanks for the comment tho.
You might want to go back to the body shop and have that looked at..
I know what do you mean. But, I bought the car that way. Thanks for the call.. Saving some money to get the rear bumper fixed.
Originally Posted by TheFarmer
You got that backwards.
my mistake...
Originally Posted by ttuberz
Itozann, loose the ghey body kit and tail lights, also get that emblem checked out bc it looks like a 5 yr old slapped it on during recess. also your front tires are bigger than your rears? your post is just full of FAIL.
ghey body kit...? hmmmmmmmmmm. I personally kinda like your car, but others might not. I believe it is a matter of taste. Please act more mature and respect others taste. Are you a forum judge? The ones who attack with words and hate.. lol.. I guess someone attacked you with the stuff you liked previously... geez... you are annoying man... I know my car is not looking like other nice cars, but two things. Part of the stuff was done when I bought it(no my dad, momo, auntie, or a loan). and I'm not rich enough to have the luxury and afford all nice and perfect things. I'm a student man, my priority is school, food and housing. So no nice or expensive stuff for now. I guess you'd not understand that. Daddy and mom got all the stuff you asked i guess... Good for you...
Anyways thanks for the comment. My bad to make a mistake. Front and rear confusion.. happens man. But, man can you be that stupid..? front tires are bigger than the rear ones in the pictures. Are you blind? do you call that a fail? man... u are annoying... you can see that the rear is bigger than the front..No wonder so many users run away from the forums. lol... Me happy with my car.. no matter what.. it was my dream car and got it.
Ariel
