Official Aggressive Wheels & Fat Tires Thread
Old Mar 28, 2012 | 09:18 PM
  #3461
1991ls13's Avatar
1991ls13
Originally Posted by OkashiZ
Forged Specialties FC6
Front: 20x9.5 +17 265/30/20 Michelin PSS
Rear: 20x11 +22 295/30/20 Michelin PSS
Hood????????
Last edited by Waiz; Mar 28, 2012 at 09:29 PM. Reason: don't quote pic strings....
Old Mar 29, 2012 | 03:13 AM
  #3462
03threefiftyz's Avatar
03threefiftyz
Originally Posted by bbs350z
i got the wheels and 2 315's for an insane steal of a price. just looking on a corresponding front tire size that will work with the 315's. they are 9.5" up front. my old setup (275/35/19) was +2 and it sat pretty flush. im just looking for no rubbing, and decent fitment.
315 on a 9.5" wheel won't work well.
Old Mar 29, 2012 | 05:36 AM
  #3463
bbs350z's Avatar
bbs350z
I understand that, the 315 is on the 10.5 wheel. I was asking for a tire to work with the 315 on the 9.5 wheel.
I was also askiong if the 315 on the 10.5 would rub with a +11 offset
Old Mar 29, 2012 | 07:25 AM
  #3464
03threefiftyz
If it clears, it will be by a razor thin margin. I don't think I have 4mm to play with on my +15.
Old Mar 29, 2012 | 07:49 AM
  #3465
scotts300's Avatar
scotts300
A 275 or 285 will nicely match the 10.5" 315 rear.
315 on a 10.5 +11 is no bueno unless you are rolled tightly and have a fair amount of camber. I like a 10.5 to be +30s with a big tire.
Old Mar 29, 2012 | 10:45 AM
  #3466
bbs350z's Avatar
bbs350z
my fenders are cut, and smoothed. slight slight pull
Old Mar 30, 2012 | 07:02 AM
  #3467
fhumphrey04's Avatar
fhumphrey04
How low are you? That will definitely make a difference too.
I'm not a fan of the tucking tire look, but a lot of people on here are. I'm running a 295 on my 10.5 +15 wheel out back with a 1/3" gap between the tire and fender. I could take some measurements if you want a reference point.
Old Mar 30, 2012 | 08:40 AM
  #3468
bbs350z's Avatar
bbs350z
^yea please. my car is not ungodly low, my tire was just meeting the fender, not tucked in yet. i wouldnt mind a little poke either, i just want traction, my main goal. and seeing as my turbo is mounted out back, i cant go much lower
Old Mar 30, 2012 | 09:15 AM
  #3469
ducky's Avatar
ducky
bbs, we are in the same boat sort of. But I'm only going for a 305/40/18 drag radial. Nonetheless z chassis have more room I was told.
Old Mar 30, 2012 | 11:55 AM
  #3470
scotts300's Avatar
scotts300
That is a hugely-tall tire. Why not go with a set-up like MT ET Streets on a set of 16s?
Old Mar 30, 2012 | 12:31 PM
  #3471
ducky's Avatar
ducky
BBK clearance issues but will test fit with brembos or sports brakes.The smallest I would go are 17s but really dont want to go lower than 18s with DRs. I need a 28" tall tire with my FD and auto to trap 150 at the top of 3rd on the 1/4mile and also doesn't hurt top speed on 4th...198
Old Mar 30, 2012 | 03:57 PM
  #3472
03threefiftyz
16's clear brembos. Trap 150mph....in 1/4? Over 1000whp?
Old Mar 30, 2012 | 04:29 PM
  #3473
ducky's Avatar
ducky
Brembos were my last resort to get the proper tire on without going to small of a wheel. I really want to use the stoptech setup 6/4 BBK.
Yes over 1000whp, v8 turbo with a 4L80e.
Old Mar 30, 2012 | 04:36 PM
  #3474
ducky's Avatar
ducky
I'm going to go ahead and order 18x10.5 R AND 18x9.5 F in +12 or +15 it's gonna have to fit...worst case is a 285 or 275 40 on the rears but I'm pretty sure the 305s will fit theoretically.I took some rough measurements for the rear, this is OEM setup.
strut to edge of fender is 12.75"
surface of hub to edge of fender is 3.5"
Now I'm rolled,pulled and banged out so it should be fine.I'm going to measure the fronts in a bit.
Old Mar 30, 2012 | 04:52 PM
  #3475
03threefiftyz
The 40 sidewall will be the only possible issue. You may have to go 35. I wouldn't want a DR, except for the street. You are going to light up an 18" DR at 100mph at that power level. Also, ditch the 4l80 and go to a glide or th400.
Old Mar 30, 2012 | 05:20 PM
  #3476
ducky's Avatar
ducky
Yea I m going to test fit some radials.. im going to light up good but it'll hook. M/T or M&H if im going 35 series otherwise Nitto DR. This will be in the street moreso but I also have another set of wheels for other purposes.
I'm sticking to the 4l80, already ordered. It can hold 1500hp and plus I get to paddle shift with it in case I want to road race on low boost.
Old Mar 30, 2012 | 09:07 PM
  #3477
805350z's Avatar
805350z
okashi, winning
Old Mar 31, 2012 | 04:51 AM
  #3478
Robert_K's Avatar
Robert_K
Didn't Go Cheap
So what do you all think. Pretty sure I'm completed with the new wheel/tire/suspension set-up. Already on the car; Hotchkis TVS kit w/ SPL End-links front & rear.
HRE P43SC Satin Black
19x9.5 +20
19x11 +25
Toyo R888 Tires
265/30-19
305/30-19
KW Variant V3 Coilovers
SPL Front Upper Arms
SPL Rear Camber Arms
SPL Eecentric Lock-Out Kit.
Old Mar 31, 2012 | 09:36 AM
  #3479
jarrodh77's Avatar
jarrodh77
It's not the most aggressive setup here, but I wanted to share my new daily setup.
Usual RPF1 18" 9.5/10.5 +15 in SBC. 275/35 front, 285/40 rear.
I planned on 295/35 rear, but I got these Goodyear F1 Supercars on closeout for $100 each and couldn't pass it up. The front pokes by just a few mm and rubs on hard bumps. I plan on dialing in a little more neg camber for autocross season anyway, so that should solve it.
Old Mar 31, 2012 | 09:38 AM
  #3480
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Looks good! Mind me asking what that set-up cost?
