Official Aggressive Wheels & Fat Tires Thread
Old May 13, 2012 | 07:14 AM
  #3761
terrasmak's Avatar
I never look at sidewall height , just overall diameter.
Old May 13, 2012 | 12:50 PM
  #3762
solidsnake's Avatar
solidsnake
Rob, You're missing your interfooler
Looks hawt son. That rear is sick with the diffuser
Old May 13, 2012 | 02:16 PM
  #3763
Robert_K's Avatar
Robert_K
Didn't Go Cheap
LOL Hopefully It will be all back together this week.
Thanks.
Old May 13, 2012 | 08:42 PM
  #3764
Trap House's Avatar
Trap House
Default Wheel/Tire Fitment?
Curious, I have a 06 350 and am looking at getting some aftermarket wheels and tires. I don't plan on dropping it, so going vs xx wouldn't look so hot. I'm trying to go for an 80's Porsche 911 look with a fatter tire on the rear, than front. Any ideas or wheels setup you have would help. Just looking for ideas and I am open to rolling fenders although not sure I'd need to if it isn't lowered.
Old May 13, 2012 | 09:31 PM
  #3765
terrasmak's Avatar
If you want wide, you need a roll. Plain and simple.
Old May 13, 2012 | 09:46 PM
  #3766
Waiz's Avatar
Waiz
Threads merged...
You might want to do some searching in this thread rather than randomly asking for ideas.
Old May 14, 2012 | 04:13 AM
  #3767
Midnight_Slide's Avatar
Midnight_Slide
Originally Posted by ProXR 440
It's really simple- 295 is the width of the tire and 35 is the percentage of the width that the sidewall will be. So 295 x .35= 103.25mm sidewall height. You need to look at the overal diameter of the tire too and not just the sidewall height. A stock 245/45-18 is 26.7" with a 110.25mm sidewall and the 295/35-19 is 27" with a 103.25mm sidewall.
I know all about tire sizes, what each number means. just my main concern is, if I go 305/30 in the rear, wouldnt my speedometer be off when the 305/35 would be closer to oem
Old May 14, 2012 | 04:20 AM
  #3768
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Play with this; http://www.rimsntires.com/specs.jsp
Old May 14, 2012 | 06:51 AM
  #3769
terrasmak's Avatar
305/30-19 is 26.3 inches tall
305/35-19 is 27.4 inches tall
I'll let you do some work now, OEM tire is 2x.x inches tall, what is closer.
Old May 14, 2012 | 01:01 PM
  #3770
scotts300's Avatar
scotts300
True for most of the wheels these goofballs look at, however, there are at least a few wheels that can take a wide tire and not require a roll.
For rears:
RPF1 18x10 +38
SSR Comp 18x10.5 +43
Volk-series of wheels in 18x10 +42
Old May 15, 2012 | 03:51 AM
  #3771
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Have to share this one. You like fat tires right?
Old May 15, 2012 | 10:36 AM
  #3772
ProXR 440's Avatar
ProXR 440
^^That things still not on the ground yet?
Here's my teaser pic... 19x10 +25 waiting for the 275/30's and fender roller to show up
Old May 15, 2012 | 12:31 PM
  #3773
3rd_gear's Avatar
3rd_gear
Your width and offset doesnt need a fender roll.
Old May 15, 2012 | 12:43 PM
  #3774
scotts300's Avatar
scotts300
Agreed.
Old May 15, 2012 | 02:13 PM
  #3775
ProXR 440's Avatar
ProXR 440
I'm also going 19x11 +25 in the rear with a 305/30. I know I need to roll the rear and from what everyone on here says is that the fender gets a slight pull during the rolling process. I'm going to take before and after measurements to see what kind of "slight pull" the fender gets during the process since I couldn't find that info anywhere, and to keep both sides even. When I test fit the wheels it looked like the rears protruded about 1/4-3/8" further than the fender. I'm assuming during the roll the fender will probably "pull" about that distance. I'd like to have the fender flush with the wheel so I'll probably pull the front to match the rear. I also plan on putting coilovers on the car soon and lowering it about an inch and want to stay within stock alignment specs. I don't plan on doing anything too crazy and I'm trying to avoid any rubbing at all since it's my DD and even the best Michigan road is on par with construction zones in other states...
Of course that's just the tentative plan and may change when I get the tires mounted and see how it all looks. Thanks for the advice and feel free to give me more I really appreciate it!
Old May 15, 2012 | 05:25 PM
  #3776
3rd_gear's Avatar
3rd_gear
Here's a rear view of some 315/35 on 17x10.5 +27. They bulge a little. Yup, they're mustang wheels.
Old May 15, 2012 | 06:31 PM
  #3777
IsDatIt's Avatar
IsDatIt
HOLLY FAWK!!!
I need a Tissue!
Props!!
Old May 15, 2012 | 08:24 PM
  #3778
solidsnake's Avatar
solidsnake
^^^^What size do you have in front? Can you post a side view of those tires please. I have 40s now and want to see the difference with 35s. Also, what brand tire? Potenza?
Old May 15, 2012 | 08:35 PM
  #3779
3rd_gear's Avatar
3rd_gear
The rears are Kumho Ecsta XS 315/35 on 17x10.5, the front are Bridgestone Potenza RE760 275/40 on 17x9.
Old May 16, 2012 | 03:14 AM
  #3780
Midnight_Slide
ah OEM is 26.3 Thanks dude
