Official Aggressive Wheels & Fat Tires Thread
Old May 8, 2012 | 10:08 PM
  #3741
13ino13's Avatar
13ino13
Originally Posted by tioga
That 295 on a 9.5 kinda looks goofy, sidewall sticking way more out then your wheels :P
You're in the wrong thread.
Old May 9, 2012 | 03:52 AM
  #3742
Midnight_Slide's Avatar
Midnight_Slide
So I have some Work Meister S1 3pc's sitting at my Parents place waiting for my visit when I come back from Afghanistan. What do you guys think would be best for wide aggressive tires. The rear fenders are rolled, front are not.
19x9.5 +20 front
19x10.5 +23 rear
Looking for some nice all around tires for the occassional track days. Im living in Texas so I do not have to worry about all weather.
If it matters, Im on Stance GR+ Pro coilovers and am boosted via Momentum Performance kit
Old May 9, 2012 | 04:14 AM
  #3743
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Front come rolled from Nissan. Depends on how much tire you like. I have a feeling the more knowledgable guys will say 265/35 & 295/30.
BTW: Get home safe! Been there, done that and now I'm back in Iraq.
Old May 11, 2012 | 11:54 AM
  #3744
4SHIZZIL's Avatar
4SHIZZIL
I did this:
to 2 of these! except I have one weld not two.... they added another rim/half to mine, vs adding a 19 inch piece in the middle! the welds are good to 1500ft lbs of tq
should be here by next weekend
woot woot!
305/30F
345/30R
FTW!
LOL
Old May 11, 2012 | 01:12 PM
  #3745
JaE35z's Avatar
JaE35z
lol damn..that deserves its own thread
Old May 11, 2012 | 01:39 PM
  #3746
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Getting closer...
Old May 11, 2012 | 07:40 PM
  #3747
Bmurray350z's Avatar
Bmurray350z
Old May 11, 2012 | 07:47 PM
  #3748
805350z's Avatar
805350z
^ finally!
Old May 12, 2012 | 02:08 AM
  #3749
4SHIZZIL's Avatar
4SHIZZIL
Lol once its dialed in and I buy those expensive azz tires I will. Lol
Old May 12, 2012 | 03:01 AM
  #3750
taywan's Avatar
taywan
4shizzle--
Wow 345s
Old May 12, 2012 | 04:17 AM
  #3751
Midnight_Slide
19x9.5 +20 front
19x10.5 +23 rear
nobody?
Old May 12, 2012 | 07:57 AM
  #3752
terrasmak's Avatar
nobody?
With that offset, 275/30 front and 305/30 rear will fill the wheel wells very nice
Old May 12, 2012 | 11:05 AM
  #3753
lgear080's Avatar
lgear080
Well said terra. How much tire do you want?
Are you trying to make a statement or do you want it dialed?
Old May 12, 2012 | 04:29 PM
  #3754
Midnight_Slide
I do like having some rubber so it does look so low pro. would 35's fit on both front and rear??
Old May 12, 2012 | 05:19 PM
  #3755
terrasmak's Avatar
255/35-19 and 285/35-19 then, but if you research aspect ratio you will find out some good info. You may even learn something.
Old May 12, 2012 | 09:41 PM
  #3756
lgear080's Avatar
lgear080
I'd say 265 - 295 Or 305 / 35 personally.
Old May 13, 2012 | 04:45 AM
  #3757
Midnight_Slide
and aspect ratio as in just google it cause Im clueless with tires to be honest.
I would really like 255/35/19 up front and 295/35/19 in the rear
Old May 13, 2012 | 05:40 AM
  #3758
taywan's Avatar
taywan
U have all that stuff on your ride and don't know about tread??
I'd mos def get those fronts rolled also.
Old May 13, 2012 | 06:31 AM
  #3759
terrasmak's Avatar
A little tall in the rear, much better of with a 305/30-19. That will also give huge a huge stagger in width, a major PITA to get the car to handle properly.
Old May 13, 2012 | 06:40 AM
  #3760
ProXR 440's Avatar
ProXR 440
It's really simple- 295 is the width of the tire and 35 is the percentage of the width that the sidewall will be. So 295 x .35= 103.25mm sidewall height. You need to look at the overal diameter of the tire too and not just the sidewall height. A stock 245/45-18 is 26.7" with a 110.25mm sidewall and the 295/35-19 is 27" with a 103.25mm sidewall.
