Official Aggressive Wheels & Fat Tires Thread
Old Jun 20, 2012 | 11:52 AM
  #3961
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
I have a customer of mine running our V710s in 19x9.5 +22/19x11 +25 with similar tire specs and he's done some rolling and a slight pull to make them fit. No reported issues after the fender work though. I imagine it will all depend on your alignment at that point, and how much fender work you are planning on doing.
Old Jun 20, 2012 | 12:02 PM
  #3962
Rjm70's Avatar
Rjm70
Yea my main concern is I dont want to have to do a pull or cut plastic etc. I want to just roll the fenders and everything roll smooth. I could go with the 275 or 285 35 rear and 245 35 front but I was looking for something with no stretch.
Old Jun 20, 2012 | 12:33 PM
  #3963
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Check out the fat tire thread. And PM members with any tire set up questions.
255/285... no stretch look at all, 245/275... little stretch look but this depend on the brand of tire b/c some brand have bulkier sidewall than others.
GL
Old Jun 20, 2012 | 01:34 PM
  #3964
Rjm70's Avatar
Rjm70
Ok thanks man I will do that. I'm sure someone is running that setup.
Old Jun 20, 2012 | 01:41 PM
  #3965
-Trav-'s Avatar
-Trav-
I ran a very similar setup, except +22 instead of +17/18. Front fit fine without issue, rears were barely flush at -1.5 camber. Dropped about 1.2". Rear was rolled completely flat which naturally gave me a few mm of pull.
Tires were pirelli p-zeros, which seem to run wide.
Old Jun 20, 2012 | 03:27 PM
  #3966
lbarge85's Avatar
lbarge85
^^those rear tires are sexxx
Old Jun 20, 2012 | 09:10 PM
  #3967
terrasmak's Avatar
Originally Posted by Rjm70
Would someone be kind enough to let me know if they had any experiences with tire sizes 295/30/19 rear and 265/30/19 front. Right now I have my wheels on order, Volk GTS 19x10.5 rear +18 and 19x9.5 front +17. I am planning on running the Hankook V12 and really need to figure out if this setup is going to work. I am also ordering the Stance coilovers to drop 1-2'' in the rear and 1" up front. I am not planning on slamming the car. The fenders will be rolled as well. Has anyone run this setup and can they tell me if I will rub?
Thanks!!!
nothing major , will fit with the normal roll , nothing else needed.
Old Jun 21, 2012 | 08:22 AM
  #3968
Rjm70's Avatar
Rjm70
Thanks Trav and Terrasmak for the info. I also heard that Hankooks run wide compared to Falken or Toyo. I might want to consider another brand in that case if I stick with that tire size.
Old Jun 21, 2012 | 12:42 PM
  #3969
Ak48z's Avatar
Ak48z
^^ you will be fine with a roll , I am on 19x11 +25's with a 305/30 hankook v12 no rubbing, lowered on GF210s.
Old Jun 21, 2012 | 04:48 PM
  #3970
terrasmak's Avatar
Yes the RS3 runs wide, the V12 is just another tire.
Old Jun 22, 2012 | 09:09 AM
  #3971
VMRWheels's Avatar
VMRWheels
+1
RS3s run pretty wide, especially compared to the Ventus V12. I'd say the V12s run pretty "true to size".
Old Jun 22, 2012 | 09:11 AM
  #3972
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I know my R888's are FAT! Wsh I had a "normal" summer tire 305 to compare to.
Old Jun 22, 2012 | 09:38 PM
  #3973
Nismomonkey's Avatar
Nismomonkey
Thought I would throw this in for the flames, I am buying new wheels so I can have a "summer" set and a "winter" set and I was thinking of going 18X8.5 Front and 18X10 rear, will this **** things up or is this not going to cause a problem being such a large stagger? I know the factory was off by .5" front to rear and you have to keep a 3% change in the sizes +/- to keep the VDC happy, but if anyone knows the formula to do math (or if its super simple and I am just retarded) let me know? I want to say this will be a 245 on the front and a 285 rear? I have some 19x8.5 now all around and they are all 245/35/19 and that doesn't mess up the VDC at all, which by some threads I have found it should. Just trying to get as wide a wheel in the back as I can for now, just for giggles really. Fear not, I brought a flame resistant suit and I can put it on if need be.
Edit:! Also the offset? I am not real clear on how this works but what should the offset be for these size wheels? Ill go back to the front and read because I think it did mention +15- +25 would work in the 18s but I am really not sure how to figure this out on my own. Perhaps if I could be pointed towards a "How to understand wheel offsets" thread?
Old Jun 22, 2012 | 09:42 PM
  #3974
lgear080's Avatar
lgear080
8.5" no way
Old Jun 22, 2012 | 09:53 PM
  #3975
Nismomonkey
So 18x8.5 front 18x9 or 9.5 rear? I did find a guy with 19x9 and 19x10.5 if my primitive math is correct, that is the same distance from a 8.5-10 is it working for him for any particular reason? I am dropping down to 18's for convenience on my part so the 10" thing isn't necessary, just a thought.
Old Jun 22, 2012 | 10:44 PM
  #3976
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Nismomonkey; http://www.rimsntires.com/specs.jsp
And those sizings are weak for this thread. There are guys running 10" & 10.5" wide front wheels with 305's squared.
Old Jun 23, 2012 | 09:28 AM
  #3977
Nismomonkey
Well how do you get a 10" wheel in the front? I imagine it would be one hell of a spacer in there or you are losing steering. Only reason I was looking at 18x8.5 for the front is because the wheels I was looking at only went out to that size before jumping to 10s. Thanks for the link though.
Old Jun 23, 2012 | 09:41 AM
  #3978
-Trav-'s Avatar
-Trav-
Camber and offset play a huge role in determining fitment, not just width. 10" up front is common, but 9.5 is the norm. Keep it simple and run the standard 9.5 front 10.5 rear with +15 to +22 offset, 255 front and keep your 285 rear. Done.
Old Jun 24, 2012 | 07:31 AM
  #3979
lgear080's Avatar
lgear080
my 10.5" wheel up front turns well on 245-295/35
Old Jun 24, 2012 | 05:19 PM
  #3980
shiftie6z's Avatar
shiftie6z
I'm running 18's. 9.5 front and 11 rear with ZERO issues. 245-40 front, 275-40 rear.
I'm looking for a tire to fit so the sidewall wont be so rediculous. Not really wanting a major "stretch", just something to add a lil aggression.
