Official Aggressive Wheels & Fat Tires Thread
Old Jan 28, 2013 | 05:55 PM
  #4501
taywan's Avatar
taywan
lol
Old Jan 28, 2013 | 06:20 PM
  #4502
InfamousMinded's Avatar
InfamousMinded
Ok let me refine what im asking.........
i plan on doin 19*11 front with 235/35/19
and 19*12 rear with 255/35/19
with 0 offset all the away round
can i pull this off and still have full steering
Old Jan 28, 2013 | 06:26 PM
  #4503
03threefiftyz's Avatar
03threefiftyz
You are not even remotely in the correct thread with those tiny *** tires...
Old Jan 28, 2013 | 06:49 PM
  #4504
InfamousMinded
19x12 rear.........this is what i plan on doin
http://farm6.static.flickr.com/5134/...2b1b35cb_o.jpg
Old Jan 28, 2013 | 07:08 PM
  #4505
03threefiftyz
Post in the correct thread!
Old Jan 28, 2013 | 09:50 PM
  #4506
terrasmak's Avatar
Lame tire sizes. Run a 265/30 front and 285/30 rear with those sizes.
Old Jan 28, 2013 | 11:55 PM
  #4507
InfamousMinded
Ok that will cover the wheel more so the rim dont stick out, still new to all of this. reason y im here
will i need a camber kit or just do it like nike
Old Jan 29, 2013 | 01:18 AM
  #4508
KingBaby's Avatar
KingBaby
Hardest Setting
Click here man
https://my350z.com/forum/wheels-and-...s-welcome.html
Old Jan 29, 2013 | 02:24 AM
  #4509
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Old Jan 29, 2013 | 04:53 AM
  #4510
2TH PWR's Avatar
2TH PWR
Maybe he meant to write. 3 instead of a 2? 235? Get real. On an 11? 2007 called they want their trend back
Old Jan 29, 2013 | 08:10 PM
  #4511
taryon's Avatar
taryon
Is this fat enough to be in this thread?
Testing out clearance of my slicks, don't worry, not driving it on the street
specs are michelin n1 cups 27/68/18 on 18x10 +26 all around, slight rubbing in the fronts.
Funny thing, these run wider than my toyo 285/35 t1rs
The sidewall in the fronts are too high so I'll probably change it back to 285 and 265s
Old Jan 29, 2013 | 08:49 PM
  #4512
RENFRO's Avatar
RENFRO
285? Geez I'm running 295 on my 10.5s out back...I'd throw some 305s on dat ****!
Old Jan 30, 2013 | 08:30 PM
  #4513
redline06's Avatar
redline06
not as fat of a tire as most of you but heres my sh!tbox
295/35/18 rear
Old Jan 31, 2013 | 07:22 AM
  #4514
STL 350Z's Avatar
STL 350Z
^Need's 305's
Old Jan 31, 2013 | 07:28 AM
  #4515
Stevo Z's Avatar
Stevo Z
Redline06 that looks good!!
Old Jan 31, 2013 | 08:21 AM
  #4516
rippn's Avatar
rippn
I have searched the threads and haven't found much with the setup I am thinking about getting. I have been using a tire size calc to make sure I stay within the 3% rule and also to find a front/rear combo that stays within 1/2" - 1" OD stagger, per the thread on what tire sizes to use with VDC. If I missed something sorry.
I recently bought my 03 6 speed touring, it is lowered 1" all around on Tokico D-speck shocks, I am not sure what springs are on it but like I said it is lowered 1" from stock ride height. The rear fender isn't rolled and front or rear isn't pulled, although I will do both if needed. It is a daily summer driver for me. I would rather not do to much with camber if possible.
Have a few questions for anyone that has this setup. Does anyone have any pics of this setup and if so do you have any VDC issues? How much are you lowered? Have you done anything with camber?
front: 19x9.5 275/30
rear: 19x11 305/30
Thanks
Old Jan 31, 2013 | 08:23 AM
  #4517
Barnabas's Avatar
Barnabas
National Z Club President
^^ need offsets
Old Jan 31, 2013 | 08:57 AM
  #4518
rippn's Avatar
rippn
Originally Posted by Barnabas
^^ need offsets
My bad, forgot offsets... front +12 rear +12 or +15. That is what I was thinking becuasue from the pics I have seen with TE-37 reps (Varrstoen probabaly since they are the one reps with 19x11 +12 that I have found).
I want a fat look without having to change camber much if at all. I like the look of 305/30, only chose 275/30 because they fit within the limits of the 3% rule and OD stagger.
Old Jan 31, 2013 | 10:48 AM
  #4519
scotts300's Avatar
scotts300
Sizes are good, will be tight with that offset though, especially the rear. Plan on some camber and rolled fenders.
Old Jan 31, 2013 | 12:38 PM
  #4520
rippn's Avatar
rippn
Do you think going to a +22 front and rear be a better fit or are you saying a smaller offset would fit better?
I would prefer the Sportline TE.6 over the Varrstoens (i wish i could afford the Volks...) but the TE.6 doesn't come in a 19x11 or a +12 offset. Maybe it would be better to go with f:19x9.5 +22 275/30 r:19x10.5 +22 305/30? Is there a noticible difference between a 10.5" and an 11" rear wheel with 305 tires, I mean is it very apparent when standing next to the car?
