Official Aggressive Wheels & Fat Tires Thread
Old Oct 22, 2013 | 09:47 PM
  #5001
KingBaby's Avatar
KingBaby
Hardest Setting
Do whatever you want at stock height...only the rear might/will need a roll.
Option 2
Old Oct 22, 2013 | 09:53 PM
  #5002
andre81k's Avatar
andre81k
In this thread they are going to say go with the second setup haha. Only problem I see is the offsets too low for the width so will poke out too much. Possibly try 19x10+20 and 19x11+25 and could do a 285/30 front and 305/30 rear. Hope that helps.
Old Oct 24, 2013 | 04:07 PM
  #5003
jgc0726's Avatar
jgc0726
Alright guys here's my setup need advice on tire
19x10 +15 front
19x11 +15 rear
On stock suspension but will lower of course and will roll fenders as well. So how BIG can I go?
Old Oct 24, 2013 | 04:36 PM
  #5004
mr. sparco's Avatar
mr. sparco
As wide as you like depending on your suspension setup.
Old Oct 24, 2013 | 04:41 PM
  #5005
jgc0726's Avatar
jgc0726
Well I'm stock now but when I lower I just want to delete gap between tire and fender
Old Oct 25, 2013 | 04:10 AM
  #5006
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well with those offsets they will stick out from the fender. For the front I say somewhere in the 255-275/30 range and for the rear 295-305/30.
For reference I run the following with KW V3 & SPL camber arms & links;
HRE P43SC w/ Toyo R888 tires (Note: The R888 run big than from other brands.)
Front: 265/30-19x9.5 +20
Rear: 305/30-19x11 +25
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-1381780_10151868651521698_1541044508_n.jpg   Official Aggressive Wheels & Fat Tires Thread-1381812_10151891412959464_2079732613_n-1.jpg
Old Oct 25, 2013 | 08:23 AM
  #5007
jgc0726's Avatar
jgc0726
Damm Robert that is a sweet ride...so what do u think about 255/35 or 30 and 295/35 or 30?
Old Oct 25, 2013 | 09:30 AM
  #5008
RAYoRAY's Avatar
RAYoRAY
What is your camber settings front and rear?
Old Oct 25, 2013 | 09:42 AM
  #5009
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I would play with this calculator if I was you. You can gain a lot of good info.
http://www.rimsntires.com/specs.jsp
To be honest it was completed several months ago and I never received a printout.
Old Oct 25, 2013 | 10:43 AM
  #5010
jgc0726's Avatar
jgc0726
Alright after playing with the calculator a little bit this is what I came up with
19x10 et 15 265/30 front
19x11 et 15 295/35 rear
What do u think?
Old Oct 25, 2013 | 11:19 AM
  #5011
tbruner's Avatar
tbruner
Play a little more with the calculator...
Tire sizes (sidewall) should be within 3% difference front and rear. The set-up you chose is over 7% larger in the rear.
Old Oct 25, 2013 | 12:03 PM
  #5012
jgc0726's Avatar
jgc0726
Can anybody please help me out with that I'm having a little trouble
I don't wanna go too wide in front and would like to have a 295 out back
Old Oct 25, 2013 | 12:18 PM
  #5013
jgc0726's Avatar
jgc0726
Originally Posted by tbruner
Playing around with tire sizes. I think this is as big as I can go with these little front wheels. 18x8.5 265/35 18x10 285/35 (295/35 next)
Tbruner what offsets are u running?
Old Oct 25, 2013 | 12:39 PM
  #5014
tbruner's Avatar
tbruner
Common setup is:
9.5 +15 Front width 265/35 or 30
10.5 +15 Rear width 285/35 or 30
Why set on 295? I guess you could do:
10 +25 Front width 275/30
11 +25 Rear width 295/30
I have sizes nobody wants... I'm broke so I don't have too many options.
18x8.5 +10 265/35 (too big for my wheel, I will be going back to 255)
18x10 +12 285/35
Old Oct 25, 2013 | 01:41 PM
  #5015
jgc0726's Avatar
jgc0726
I have sizes nobody wants... I'm broke so I don't have too many options. 18x8.5 +10 265/35 (too big for my wheel, I will be going back to 255) 18x10 +12 285/35
Lol we on the same boat...I already bought wheels sizes 19x10 +15 so I can go 2 ways from here either put the 19x10's up front or put them out back and go with 8.5's +15 out front, the wheels I got don't make 9's or 9.5's.
With that being said I'm just gonna go 8.5 up front and put the 19x10's in the rear and I'll go with 255/35 up front and 285/35 or 295 not sure.
Old Oct 25, 2013 | 02:28 PM
  #5016
tbruner's Avatar
tbruner
Then do 10" +15 in the front. You will regret 8.5", I do...
What wheels are you looking at?
Old Oct 25, 2013 | 03:56 PM
  #5017
jgc0726's Avatar
jgc0726
Then do 10" +15 in the front. You will regret 8.5", I do... What wheels are you looking at?
Well like you I'm broke as well so I bought xxr 531 can't afford high end wheels.
Why will I regret 8.5?
Old Oct 25, 2013 | 06:17 PM
  #5018
mr. sparco's Avatar
mr. sparco
Why else? It'll look like dookie.
Old Oct 25, 2013 | 06:26 PM
  #5019
jgc0726's Avatar
jgc0726
Lol well I made up my mind ima go 19x10 front and 19x10 rear +15 all around and in tires I'll just go with 255/35 front and 275/35 rear
Old Oct 28, 2013 | 07:33 AM
  #5020
tbruner's Avatar
tbruner
That's better, but those tire sizes wont allow you to post in here...
You could go bigger. I would try 265 F & 285 R
