Official Aggressive Wheels & Fat Tires Thread
Old Jul 29, 2013 | 05:33 PM
  #4921
NA&CH's Avatar
NA&CH
Plus 1!!! Looks killer brother!
Chris
Old Aug 4, 2013 | 04:14 PM
  #4922
flipvision3's Avatar
flipvision3
my contribution!
Enkei RPF1
18x9.5 +15 265/35/18
18x10.5 +15 295/35/18
Old Aug 4, 2013 | 04:21 PM
  #4923
taryon's Avatar
taryon
^ Very nice!
Old Aug 4, 2013 | 06:20 PM
  #4924
terrasmak's Avatar
Originally Posted by Colombo
0 offset (after spacer) 245/40/18 18x8.5 front Nitto NT05 285/35 rear NT05 +5 offset Rear 18x10
Originally Posted by madril350z
Quick question do most people take out there fender liners? i am going to have to but is this the common practice just curious. Thanks
mine 19x9.5 19x10.5 +12 255/35/19 285/35/19
Please remove your post till you have some wide front tires. 245/255 fronts are pathetic/common.
Old Aug 4, 2013 | 06:23 PM
  #4925
JaE35z's Avatar
JaE35z
Old Aug 8, 2013 | 06:16 AM
  #4926
4SHIZZIL's Avatar
4SHIZZIL
I cant remember but I believe the tire mounted on the rear in these pics are my fronts. 275/35/19
slight rub on hard dips...
345/25/19 would fit like a champ.....too bad no one makes that size.
Moving to the GTR 20, getting those widened, then going with 345/25/20 which will be right on the money.
Old Aug 8, 2013 | 06:58 AM
  #4927
jduet's Avatar
jduet
Wow
Old Aug 8, 2013 | 08:26 AM
  #4928
Robert_K's Avatar
Robert_K
Didn't Go Cheap
4SHIZZIL! What are the wheel specs?
Old Aug 8, 2013 | 01:10 PM
  #4929
KingBaby's Avatar
KingBaby
Hardest Setting
lord have mercy
  #4930
-Trav-'s Avatar
-Trav-
Hell yea man! More shots of the rear from further out would be great.
Old Aug 8, 2013 | 01:48 PM
  #4931
jdmlove1's Avatar
jdmlove1
^^ ur diff is crying with these tires
Old Aug 8, 2013 | 07:58 PM
  #4932
slmdchvy05's Avatar
slmdchvy05
That's crazy...... I love it, very aggressive.
Old Aug 9, 2013 | 10:53 AM
  #4933
4SHIZZIL's Avatar
4SHIZZIL
hmm thats tricky
I started with 6 stock rear 370z 19s (19x10 on all fours)
I sent two off to Weldcraft for a 2 inch addition. tested the 275 and 305 on the fronts
Stock i think is +30, adding 2 inches or 25.4 x 2 = 58.4mm to the inside.
higher offset
So I guess that makes it a +88.4
Then I added a 25mm spacers, pulling it out.
lower offest
making it a +63.4-ish LOL
19X10F +30 305/30/19
19x12R + 63 ish 345/35/19
note this tire should of been a 25 series, it did rub the rear part where the rear fender and bumper come together. I didnt feel like busting out the drimmil so I took the 345s off, especially noticing that the tire was the wrong size. Totally 1.5 inches taller and .5 inches wider than I guessed and that bish still fit.
I could drive it to a show and back, but that will require a non boosted rum. Only rubbed on hard dips, and im not that low. So to save the tire I took it off....... for now...More to come this winter or next spring
Old Aug 9, 2013 | 10:58 AM
  #4934
4SHIZZIL's Avatar
4SHIZZIL
no more so than when it puts down 557rwhp and 460rwtq (ish)
ive been saying it could be done for years, no one would believe me.
I am not running coil overs. it did rub the inner fwd fender for about a minute...never had minor rubbing fwd wise in inner rear fender bfore.
The rear can be trimmed and done, but I said I would do a 345 without flares so Ill try the 20 inch before I do the feder mods to get these to work like I measured.
I always have run stock camber too guys. LOL
Old Aug 9, 2013 | 02:34 PM
  #4935
X.et's Avatar
X.et
Currently running 255/35/19 front, 285/35/19 rears. I have bubble in one of my rears and was considering going up to 305/30/19's in the rear, fronts I can either leave as 255/35 or up to 275/35. Any input on if their would be any issues with either setup or if one is preferential over the other?
Rims are 9.5/10.5 +12, not really worried about rubbing since I'm rolled in the rears and can always raise the car a bit if needed.
Old Aug 9, 2013 | 02:46 PM
  #4936
jdmlove1's Avatar
jdmlove1
^^ i was runnin 285 35 19 with nitto invo and 9.5 +22 offset with 5mm spacer & fender rolled.. the tires were rubbing!!!! i removed the spacers now its ok!!
how come u runnin 285 +12 and u dont rub!! i guess nitto invo side wall is too big!
note am lowered with tein s-techs + rear spring mount mode.. still one finger gap
Old Aug 9, 2013 | 02:52 PM
  #4937
X.et's Avatar
X.et
lol no idea, I may have a bit more gap then you, but not sure if enough that it would make the difference. Did you just rub on bumps? Or normally? Here is a pic of my current rears
Old Aug 9, 2013 | 03:42 PM
  #4938
taryon's Avatar
taryon
I have 19x10.5 +12 in the rear with 285/35/19 and 1 finger gap and don't have any rubbing issues
I'm guessing it could be due to your height or your fender needs more rolling
Old Aug 10, 2013 | 03:32 AM
  #4939
jdmlove1's Avatar
jdmlove1
well, i think the reason is coz my wheels are 9.5 not 10.5.. so the tires side wall is like a baloon on my wheels. that why i was rubbing
Old Aug 10, 2013 | 04:31 AM
  #4940
taryon's Avatar
taryon
Since we have the same size tires and you have it on a bit of the bulgy side, wouldn't that be equal to or less than same width as the 285 on the 10.5?
Or it could be your tire design as well, for example my 265/40/18 michelin ps2 ran similar to a 285
