Official Aggressive Wheels & Fat Tires Thread
Old Feb 20, 2014 | 04:23 PM
  #5161
ARSZ34's Avatar
ARSZ34
Originally Posted by Waizzz
Baby steps
That's fine, just doesn't belong in this thread
You have a nice setup don't get me wrong, you are only half way there with aggressive offsets and undersized tires
Thanks, I appreciate the input. Maybe down the road when I feel the need for wider tires Ill repost. BTW, whats the official minimum to qualify to post in this thread. Just curious...
Old Feb 20, 2014 | 04:26 PM
  #5162
CJM's Avatar
CJM
Noob question inbound: How are you guys keeping the VDC happy while running 295/305 etc? I used the calculator and it was more than a 3% difference. Unless you run a 30 series tire, which I thought was taboo?
Old Feb 20, 2014 | 06:38 PM
  #5163
terrasmak's Avatar
are we talking 19's , you probably want a 30 series for a 295/305 rear.
Old Feb 20, 2014 | 06:42 PM
  #5164
CJM's Avatar
CJM
Didn't include diameter but thank you. Was just curious since I've heard bad things about 30 series tires. Might go with a 285/35-19 rear then due to poor roads.
EDIT: Just ran the numbers again and must've screwed up the first time. The difference is only 2.65% for a 305/35 from 245/45. Do you still recommend a 30 series? Wheels will be 10.5 or 11 inches wide with about +15 offset. Mild (1"-1.25") drop on coils.
Old Feb 20, 2014 | 07:09 PM
  #5165
herrschaft's Avatar
herrschaft
You probably can't run a 30 series tire with a 245/45 up front, I guarantee it would look stupid too. I run a 30 series all around and the only bad thing I've experienced is ride comfort.
Old Feb 20, 2014 | 07:23 PM
  #5166
CJM's Avatar
CJM
I should stop multitasking tonight. As of now, I plan on 245/35-19 front with a 285/35-19 rear. (3.18% difference is bueno).
Old Feb 20, 2014 | 07:34 PM
  #5167
SR71's Avatar
SR71
Lead Super Moderator
Not fat tire worthy though.
Old Feb 20, 2014 | 08:00 PM
  #5168
CJM's Avatar
CJM
Was going to be, but I talked myself out of it sadtimes
Old Feb 20, 2014 | 11:00 PM
  #5169
terrasmak's Avatar
305/30-19 rear with a 245/35-19 would work fine, it's more of a setup for a high power car that is set up for point and shoot in the corners. A 275/30-19 would also work great up front with that rear size and give better handling.
Old Feb 21, 2014 | 11:44 PM
  #5170
Optimist Run's Avatar
Optimist Run
Default Want a meatier tire setup. Help reducing stretch.
NEED HELP! I want a a much meatier tire but I am wondering if I can make it work with pulling and rolling the fenders.
I am currently running 19x11 offset +25 all the way around with a 5mm spacer upfront and a 20mm spacer in the back. My tire stretch is aggressive at 245/35. I want to increase this to 265/35 or 275/35 for a meatier look.
Will it work?
Old Feb 25, 2014 | 05:00 PM
  #5171
ConradoR's Avatar
ConradoR
Hey guys I'm getting ready for my LS swap in 2 months (everything bought, not a dream build), and as I'll be losing VDC, I need to get all I can from the tires (Sways, coils, arms, all done).
Volk gts 9.5 +17 10.5 +18. I just got new wider rears (pic below) ...hankook v12 305/30/19. Fronts are currently 245/35/19. What should I go with, that would work best with the new rears (traction is a priority, but I'm sure it will help with the current wheel gap!). 255/35? 275/35?? I'm not sure.
Thanks for the help!
Old Feb 25, 2014 | 05:12 PM
  #5172
CJM's Avatar
CJM
Here's the answer terra gave me two posts up...should help you.
Old Feb 26, 2014 | 04:21 AM
  #5173
ConradoR's Avatar
ConradoR
damn 275 up front thats so crazy that's what I have always ran at the rears!
Old Feb 26, 2014 | 07:31 AM
  #5174
scotts300's Avatar
scotts300
275s actually end up being rather easy to run up front. Most of the track guys even run 285s, and I did a stint with front 305s for awhile as well. GRIP.
Old Feb 26, 2014 | 10:20 AM
  #5175
Waiz's Avatar
Waiz
Depends on your specs
275 on a 10.5 for instance is not aggressive
Old Feb 26, 2014 | 05:13 PM
  #5176
ARSZ34's Avatar
ARSZ34
Depends on your specs 275 on a 10.5 for instance is not aggressive
I kind of got that... 275 is not aggressive on a 10.5... So would 285 on a 10.5 suffice as a minimum?
Old Feb 26, 2014 | 05:28 PM
  #5177
03threefiftyz's Avatar
03threefiftyz
Poosie's....
Old Feb 26, 2014 | 05:42 PM
  #5178
Bmurray350z's Avatar
Bmurray350z
Those wheels look yummy. How much do they weigh?
Old Feb 26, 2014 | 05:45 PM
  #5179
ARSZ34's Avatar
ARSZ34
What are the specs (tire size/offset) on your CCW's in that pic? Look great!! Also, how much camber are you running?
Old Feb 26, 2014 | 05:57 PM
  #5180
03threefiftyz
23lbs for the 18x12's. Not that light.
315/30/18 18x11 +10 18x12 +17. I use -2.7 up front.
