Official Aggressive Wheels & Fat Tires Thread
Old Jan 11, 2011 | 10:32 PM
  #1481
SQBassHead's Avatar
SQBassHead
Originally Posted by Waizzz
Somewhat true, but only if you tell yourself that
... you know im right
Old Jan 12, 2011 | 05:29 AM
  #1482
350Z_Al's Avatar
350Z_Al
Originally Posted by Voboy
I run/ran a 19x10.5 +35 with 285 tire and it cleared just fine... But I never checked if I had more room to work with or not... Offset calculator says it's only a 2MM difference for inner clearance. Most likely will clear... if not you can always run a small 3-5mm spacer.
Perfect! That's what I was looking for, a real world example. I'm not too worried about 2mm, thanks!
Old Jan 12, 2011 | 06:11 AM
  #1483
porschett's Avatar
porschett
Default Tire & Wheel fitment
Just picked up a 04.5 Touring. It's stock and will remain that way for now. Looking for recommendation on wheels/tires. I'd like to go as wide as possible without body mods. I was thinking 9.5x18 & 10.5x18 w/245/40 and 275/35. Is this possible and what would you use for offsets?
Thanks in advance!
Old Jan 12, 2011 | 06:46 AM
  #1484
nismonian's Avatar
nismonian
Thanks in advance!
get your rear fenders rolled and you can run a 18x10.5 +15 rpf1's all the way around. 275/35f 285/35r. a perfect combo, imo.
Old Jan 12, 2011 | 12:31 PM
  #1485
Barnabas's Avatar
Barnabas
National Z Club President
and doing a mild roll is not a big deal its a easy DIY or take it to a experienced shop that you trust
Old Jan 12, 2011 | 01:13 PM
  #1486
scotts300's Avatar
scotts300
I have seen 275s rub on the front with the RPF1 18x9.5+15, and the 10.5+15 would be even worse. The tires were a set of Kumho XSs that may run a little chubby. He rubbed in the back on the same wheel as well. After a lousy roll, they still rub on occasion.
Old Jan 12, 2011 | 01:51 PM
  #1487
nismonian's Avatar
nismonian
ive driven my buddies Z alot, and it never rubbed.. he was also lowered on coils in the front. the guy i bought my new wheels off of had 275/35 in the front and those were 18x9 +20 and no probs either...
alignment and tire selection plays a big roll though...
Old Jan 12, 2011 | 02:00 PM
  #1488
03threefiftyz's Avatar
03threefiftyz
I run 285's on 9" wheels with +20 on the front...no roll or rub. I do run about -3.1 camber though.
  #1489
KingBaby's Avatar
KingBaby
Hardest Setting
pics?
Old Jan 12, 2011 | 02:01 PM
  #1490
03threefiftyz
me?
Old Jan 12, 2011 | 02:15 PM
  #1491
scotts300's Avatar
scotts300
Yup, different tires can make the difference. Your 18x9+20 set is quite different than the sets we have been discussing though. I have driven his car on the street, autox, and track, and it rubs a bunch.
Very similar to my old set up (see below).
Originally Posted by KingBaby
pics?
Here are a few pics of 18x9x4 +21 with 285/30/18 tires:
Old Jan 12, 2011 | 02:23 PM
  #1492
KingBaby's Avatar
KingBaby
Hardest Setting
me?
no late post...mean't the guy above you...
I probably over looked this or forgot...
what suspension do you have?
Old Jan 12, 2011 | 03:14 PM
  #1493
nismonian's Avatar
nismonian
pics?
check out post #1436 i posted a couple pics of his Z.
Old Jan 12, 2011 | 03:43 PM
  #1494
porschett's Avatar
porschett
Is my thread being jacked?
Old Jan 12, 2011 | 03:47 PM
  #1495
porschett's Avatar
porschett
I'd like to stay away from 275's up front. I like the look of the 245 and something wider in the rear. I'd go 305 if I could. Problem I have here is finding a shop to do the rolling of the fenders. I'm currently in New Bern, if anyone knows of a body shop that knows what they're doing.
T I A
Old Jan 12, 2011 | 04:52 PM
  #1496
03threefiftyz
He's on truechoice DA Konis w/custom springs.
Old Jan 12, 2011 | 09:32 PM
  #1497
scotts300's Avatar
scotts300
T I A
If you get higher offset wheels, like the RP03 +30, you could run 305.
Old Jan 12, 2011 | 10:03 PM
  #1498
KingBaby's Avatar
KingBaby
Hardest Setting
oh...
thought that was yours....
thanks getting confused...
Old Jan 13, 2011 | 04:15 AM
  #1499
porschett's Avatar
porschett
Default Found these
Enkei RPF1 Staggered Combo (18x9.5/18x10.5, 5x114.3) for just over $1300 shipped. Is this a good deal and will they fit?
Old Jan 13, 2011 | 04:39 AM
  #1500
0jiggy0's Avatar
0jiggy0
Thats the going price.
