235/40/18 Front 255/40/18 Rear
Old Jul 5, 2009 | 11:16 PM
spddmn124's Avatar
spddmn124
Default 235/40/18 Front 255/40/18 Rear
anyone using this setup??
anyone having problems with VDC or anything particular?
Thanks in advance!
Old Jul 6, 2009 | 04:36 AM
DavesZ#3's Avatar
DavesZ#3
It's not one of the common setups but you shouldn't have any problems with VDC/TCS. The F/R diam diff is 0.6" which should be perfect. The OD is a little smaller than OEM so it will throw off the speedometer/odometer only slightly.
Old Jul 6, 2009 | 04:43 AM
The number of potential tire combinations is endless. Why would the NOT work?
Old Jul 6, 2009 | 05:03 AM
DemitriHKS's Avatar
DemitriHKS
That should work. Its not common like they said but it would be fine.
Old Jul 6, 2009 | 08:25 AM
bballgms's Avatar
bballgms
would there be a problem doing a 225/45/17 and 245/45/17 setup? on the stock 17in rim.
or would it be better if i did 225/45/17 and 235/45/17?
Old Jul 6, 2009 | 11:04 AM
DavesZ#3's Avatar
DavesZ#3
Neither combination is optimal but I would go with the 225/245.
The stock tire sizes and Outside Diameters are:
225/50/17 25.9"
235/50/17 26.3" (0.4" stagger)
Your choices:
225/45 25"
245/45 25.7"
225/45 25"
235/45 25.3"
Because the 45 profile is shorter than the OEM 50 profile, all combinations are shorter than the OEM setup. That throws your speedo/odometer off a bit. I'm guessing you don't have TCS or VDC but if you did, the stagger is still there and within tolerance so you wouldn't have a problem there.
Old Jul 6, 2009 | 11:15 AM
spddmn124's Avatar
spddmn124
wow, thanks for your help, what is the "common" setup??
Old Jul 6, 2009 | 11:54 AM
DavesZ#3's Avatar
DavesZ#3
The normal/common setup would be 225/245 to match OEM size, the plus-size would be 235/275 on wider wheels. Your 235/255 is like a half-step up, giving you slightly wider tires.
Old Jul 6, 2009 | 11:59 AM
bballgms's Avatar
bballgms
225/50/17 25.9"
Your choices:
225/45 25"
245/45 25.7"
225/45 25"
235/45 25.3"
would it be better do do the 235/45 or 245/45 setup in the back which one would be better?
Old Jul 6, 2009 | 09:06 PM
bballgms's Avatar
bballgms
or should i stay stock. the reason i want to do the 45 profile is bc i want to get the eagle f1 asymetrics.
Old Jul 7, 2009 | 03:30 AM
DavesZ#3's Avatar
DavesZ#3
245 would be "better" in the sense that it would be a slightly wider tire giving you slightly more traction.
There's no overriding reason to stick with the 50 profile tire other than the speedo/odometer accuracy. You won't be off by much though so I wouldn't sweat it.
Old Jul 7, 2009 | 06:44 AM
bballgms's Avatar
bballgms
is the speedometer on the wheel on the front wheel or the back wheel?
Old Jul 7, 2009 | 07:51 AM
scotts300's Avatar
scotts300
Drop the clutch from a stop and watch the speedo and the scenery - report back.
Old Jul 8, 2009 | 10:34 AM
350ZthatsMe's Avatar
350ZthatsMe
my friend is running that setup on his Z w/o any problems... but it has a 0.5" lower sidewall than stock setup, which means more wheel gap...
Obadabot
Jun 18, 2023 11:31 PM
