What OEM wheels can I fit on an 06 Grand Touring Z?
Old Jul 21, 2009 | 08:39 AM
interruptinmoss's Avatar
interruptinmoss
Default What OEM wheels can I fit on an 06 Grand Touring Z?
Because the brake calipers are much larger there can be issues with the spokes hitting them (one dealership already borked me on this while chasing down a problem).
Can I put any 18" OEM wheels on there? Probably not 17"...
Any suggestions as what will fit and would be suitable for a set of all-season tires? The standard 18/19 combination wheels that came with the grand touring model are being relegated to summer only.
Old Jul 21, 2009 | 08:48 AM
rockinbboy's Avatar
rockinbboy
no no on the 17s. 18s should be fine all around for your brakes. Rears brakes are bit smaller than the front ones.
Old Jul 21, 2009 | 09:28 AM
terrasmak's Avatar
Everything but the OEM 17 will fit, unless you run a 5mm spacer , then the 17's will also fit
Old Jul 21, 2009 | 11:23 AM
Look at OEM wheels specs. Compare width and offset. That will give you a good start.
Old Jul 21, 2009 | 11:27 AM
Nexx's Avatar
Nexx
why no no on the 17's? the oem 17's fit over the oem brembos..
m_0g
Jun 3, 2021 10:05 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
