Question about Spacers and Lug Nuts...
Old Jul 28, 2009 | 01:32 PM
VQpoweredZ's Avatar
VQpoweredZ
Default Question about Spacers and Lug Nuts...
Hello,
I hope you guys can help me out with a few questions I have regarding my Z. I am looking to purchase the Ichiba V2 Hub centric 20mm spacers for my 19 inch LMGT4's. My Rim and tire specs are as follows...
19x8.5+25 - Tire 245/35/19
19x9.5+30 - Tire 275/35/19
With the spacers installed I would have the offsets at +5 in the front and +10 in the back. My car ISN'T lowered and is at stock height. I was wondering if any of you knowledgable wheel experts could tell me if I were going to rub with this set up. Also is having a higher offset in the back going to look weird when the spacers are installed? Or should I get a 20mm pair for the front and 25 mm pair in the back to get my rims at +5 all around?
Another question is will the Rays Duralumin Black Long Lug nuts (12x1.25) fit on my Nismo LMGT4's? Heres the link...
http://www.mynismo.com/products/?id=3974#
Thanks you guys very much, any help is appreciated.
Dan
Old Jul 28, 2009 | 02:15 PM
VQpoweredZ's Avatar
VQpoweredZ
bump
Old Jul 28, 2009 | 03:31 PM
VQpoweredZ's Avatar
VQpoweredZ
any help?
Old Jul 28, 2009 | 03:40 PM
BarefootRacer's Avatar
BarefootRacer
Lugs nuts will work on your wheels for sure.
As far as the spacers go i would do the 20mm front and the 25mm rear. This setup wont rub, you will have plenty of room since it will still be a pretty conservative offset due to the wheel widths.
Old Jul 28, 2009 | 05:23 PM
terrasmak's Avatar
+15 on a 9.5 with stock suspension will rub (depending on your camber) We have a large camber range in the rear from the factory, some cars will rub , others will not. If you do rub , it will take a large bump to make it happen.
Old Jul 28, 2009 | 05:29 PM
doug's Avatar
doug
you're going to rub over bumps.. stock suspension or not
