Cause of abnormal wear?
Old Aug 8, 2009 | 10:45 AM
quakerroatmeal's Avatar
quakerroatmeal
Default Cause of abnormal wear?
Took my wheels off today and notice 1 of my tire (rear driver side) has a odd abnormal wear in the middle/towards left a little more and I have no idea why.
I'm lowered, I have rear camber kit on the rear with toe bolts. Alignment is perfectly within spec and my tire pressure is normally around 33-35.
Old Aug 8, 2009 | 11:11 AM
tylerxfire's Avatar
tylerxfire
u will have that with this car...do u have a 03? this is a big discussion search around..
Old Aug 8, 2009 | 11:13 AM
quakerroatmeal
It's an 04.5. I don't remember it happening before I changed wheels/tires.
Old Aug 8, 2009 | 11:19 AM
terrasmak's Avatar
Originally Posted by tylerxfire
u will have that with this car...do u have a 03? this is a big discussion search around..tire feathering
On a rear tire, are you serious. Not to mention if you knew anything , feathering is just an alignment problem and all years have had that problem.
Old Aug 8, 2009 | 11:24 AM
*Boose*'s Avatar
*Boose*
That's weird chicken strip on a car.
Old Aug 8, 2009 | 11:27 AM
It appears that the inside of the tire is “rubbed clean.” Inspect inside the fender well. What are you rubbing?
Old Aug 8, 2009 | 11:35 AM
tylerxfire's Avatar
tylerxfire
ah really i had no idea that feathering was an alignment problem...wow thank u so much for clearing up the obvious..did i say only the 03's had that problem NO!!! , i was just curious as mine is a 03 and i had the exact same thing happening.. both my rear tires wear slightly faster on the insides of the tires which im assuming is happening here..i wouldnt worry about it because if its changed in the alignment it will take away from the handling in the car.. i had a vette come in the shop the other day that was also experiencing it, it is common on some bmw's too i have seen
Old Aug 8, 2009 | 11:37 AM
tylerxfire's Avatar
tylerxfire
i think that rubbing would be noticed while driving and would tear up the tire more but could be happening.. what is ur tire psi on that tire vs. the other side? are both doing it at all or just the one?
Old Aug 8, 2009 | 12:22 PM
quakerroatmeal
I am having minor rubbing actually but its not in that area when I looked. I'm rubbing where I rolled my rear fenders it shouldn't hit the middle area of the tire?
It's only 1 tire that I notice looks different.
Maybe the fender wells buit up in dirt and is hitting against my tire. I'll look some more.
Old Aug 8, 2009 | 08:48 PM
The fender well is plastic so a friction area should not be difficult to see. I am interested in the outcome.
Old Aug 9, 2009 | 08:21 AM
endless_summers's Avatar
endless_summers
Why is there so much talk about feathering? there is no feathering on that tire. It looks like something inside the fender well is rubbing against the tire.
This is feathering:
And the tire looks to be wearing very well for a rear tire on a Z that's lowered.
Rear this about tire wear: http://tireguides.com/print_friendly...tails&ttcid=10
You just have something rubbing against the tire while you're driving.
Old Aug 9, 2009 | 08:26 AM
tylerxfire's Avatar
tylerxfire
This is feathering:
there is not so much talk of tire feathering..i guess i worded it wrong in the beginning..i understand what tire feathering is..the tire to me really seems to be wearing just fine as its on a lowered z that seem to do this right from factory anyway..i have seen this many times..i am betting it is not rubbing anything but could be i guess..just to me i would notice something rubbing instantly
Old Aug 9, 2009 | 08:29 AM
tylerxfire's Avatar
tylerxfire
idk i mean signs point to rubbing, but what the hell would it be rubbing down the middle like that...really seems if it was gonna rub it would rub the outside of the tire..op update asap
Old Aug 9, 2009 | 08:46 AM
quakerroatmeal
I came to conclusion that it's because of how low I am and if I hit huge dips it'll rub down the middle. And the hwy here I go on has a huge dip I go through everyday. Rubbing on the side as well but that's not even noticeable on the sidewall at all. I need to upgrade my shocks.
I thought it was rubbing on the sidewall only at first until I took the tire off and wondered why it look so weird.
Can't really tell from the rear fender plastic because of how dirty it is and I cannot clean it because of clearance (can't jack up the car in my driveway either cause its slanted.
DarkCreep
Oct 17, 2015 11:50 PM
emooheo
Oct 14, 2015 08:58 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
