TPMS issues tire pressure reading "--"
Old Aug 13, 2009 | 07:13 AM
CRAZY Z's Avatar
CRAZY Z
Default TPMS issues tire pressure reading "--"
Okay, I have been searching high and low to figure out what is wrong with my TPMS. At first just my left front tire was reading high but it actually was perfect and then sometimes it would read 0 but be perfect as well. Well, now both fronts read "--" . i have tried doing a ECU you reset with no luck. I have tried the trick of putting the system in learn mode by take the single little wire that is beside the tire pressure unit under the passenger dash and taping it to ground five times and to see if that would make the low pressure indicator on the dash blink but it doesn't do it. With all this said it is driving me a little nuts now. My rears work fine. I have volk 19s with the tpms banding method being applied. I have had them banded for 2 years almost.
Does anymore no anything I can try to resolve this issue? Also, my my tire system doesn't beep anymore like I remember it doing when I first got the car with a low tire and nor does the light on the dash come on.
Thanks
CRAZY Z
Old Aug 13, 2009 | 07:30 AM
WhiteNoiz's Avatar
WhiteNoiz
Dude... your Z is crazy
Old Aug 13, 2009 | 08:13 AM
GeauxLadyZ's Avatar
GeauxLadyZ
change the front sensors out...
Old Aug 13, 2009 | 09:07 AM
Globalscan's Avatar
Globalscan
Sounds like the sensors are not communicating. I would start by replacing one to see if you have a static reading at that point. If so, replace the other one.
You may be able to find used ones from someone who went with aftermarket wheels and said screw it on the TPMS and didnt bother to use the bands
Old Aug 13, 2009 | 09:13 AM
cheshirecat79's Avatar
cheshirecat79
Mine is doing the same thing right now. At times it was intermittently the rears- one may go out 30 minutes into a drive, sometimes both. After the car was restarted, they would communicate fine.
Now it's my front right that isn't communicating. I don't know what it is.
Old Aug 13, 2009 | 09:29 AM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by CRAZY Z
... I have tried the trick of putting the system in learn mode by take the single little wire that is beside the tire pressure unit under the passenger dash and taping it to ground five times and to see if that would make the low pressure indicator on the dash blink but it doesn't do it....
HUH??? That WOULD be a neat trick if it actually did anything.
It sounds like either the sensor in that wheel has died or it is no longer registered with the ECU and needs to be reset/registered.
Old Aug 13, 2009 | 09:57 AM
CRAZY Z's Avatar
CRAZY Z
i wish someone with a working system could try this and see if it works. i know it works on the G35s.
http://g35driver.com/forums/wheels-t...ial-tools.html
Old Aug 14, 2009 | 07:09 AM
Thermal1's Avatar
Thermal1
Mine did the same thing when they came loose from their bands... Are they bouncing around inside the tire? You can hear them at low speed...
Old Aug 14, 2009 | 01:42 PM
Globalscan's Avatar
Globalscan
Used TPMS currently in Market place
Old Sep 9, 2009 | 07:09 PM
joepro's Avatar
joepro
could you give me more info on the wire trick, where is the unit under the dash? I know the guys at the nissan dealer but dont feel like asking for a favor, they will want a case of beer for resetting the tmps sensors haha.
Old Sep 10, 2009 | 03:33 AM
DavesZ#3's Avatar
DavesZ#3
You'll probably do better asking the guys on G35driver who actually did the "trick". I've yet to see anybody here claim to do it and make it work.
Old Sep 10, 2009 | 06:51 PM
joepro's Avatar
joepro
I saw the thread on g35 that says it works, but there was a link to the obd3 site that had the grounding procedure but the link was dead.
Old Sep 10, 2009 | 07:10 PM
Spike100's Avatar
Spike100
^^ The link is dead for probably a good reason. If the technique works reliably, the link would be alive and active.
--Spike
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Depravity
Oct 1, 2015 04:49 PM
