wheel size fitment question
Old Sep 16, 2009 | 04:12 AM
sky14's Avatar
sky14
Default wheel size fitment question
well im about to pick up a z and i have my wheels from my 240 laying around.
i was wondering will
19 * 10 - 6 with 245 25 19s
19 * 12 -12 with 335 25 19s fit on a stock body ?
if not over fenders and mad camber?
or camber on a stock body ?
thanks
mikey
Old Sep 16, 2009 | 04:21 AM
BLUby_U's Avatar
BLUby_U
What type of wheels do you have laying around?
Old Sep 16, 2009 | 04:24 AM
BLUby_U's Avatar
BLUby_U
mad camber is right! maybe just a simple roll and a stretched rear tire will set it off nice.check out r i m t u c k . c o m or this thread for more help. ORhttps://my350z.com/forum/wheels-and-tires/318066-aggressive-wheels-and-stretched-tires-welcome-201.html <--- Fitment kings
Old Sep 16, 2009 | 07:11 AM
scotts300's Avatar
scotts300
19 * 12 -12 with 335 20 19s fit on a stock body ?
thanks
mikey
Absolutely friggin' not.
You did mean to have the negative offset not positive offset, right?
BTW, I've seen your white clip-on flared 240SX before, but think it's highly unlikely that you had 335 tires on the rear.
Old Sep 16, 2009 | 07:42 AM
sky14's Avatar
sky14
yup i got 335s on them now lol..
yeah they are negative six and negative 12
so u dont think these rims will fit ?
thanks for ur input guys
Old Sep 16, 2009 | 07:43 AM
sky14's Avatar
sky14
double post
ill jsut use the double post to post a pic of the rims
Old Sep 16, 2009 | 08:08 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Sep 16, 2009 | 08:14 AM
Jacob350z's Avatar
Jacob350z
yea they would fit.
id never got with that size tire wall but thats on you. with that offset you might need that low of a tire wall. should fit with a good bit of camber. get some pics!
Old Sep 16, 2009 | 08:26 AM
sky14's Avatar
sky14
sorry about the wrong section mods.
and thanks jacob!
i cant waitt
Old Sep 16, 2009 | 09:16 AM
Done Deal DR's Avatar
Done Deal DR
Originally Posted by Jacob350z
yea they would fit.
WTF are you talking about?
This [19 * 10 - 6 with 245 25 19s] will probably fit with a lot of negative camber, will likely still rub.
This [19 * 12 -12 with 335 20 19s] is not even REMOTELY close to fitting. You could not fit this with 15 degrees of negative camber. You would need a huge widebody to even be close to fitting this. With all due respect, you shouldn't keep popping into threads saying outrageous stuff will fit when it absolutely WILL NOT. He would have trouble fitting that wheel with a ton of negative camber with a 255.
One more thing, a 90mm stagger front to rear will make your car drive like a FWD Civic () unless you have 500+ hp, even then it will understeer like crazy unless further chassis modifications are done, properly. I can't, off the top of my head, think of anybody that has run a stagger that high with the 350z/G35 platform, and for good reason.
Old Sep 16, 2009 | 09:19 AM
Done Deal DR
Also, I don't believe a 335/20/19 tire exists.
Old Sep 16, 2009 | 09:21 AM
sky14's Avatar
sky14
there perrellie rossos tires
Old Sep 16, 2009 | 09:30 AM
jerseymike68's Avatar
jerseymike68
Thank You!
Old Sep 16, 2009 | 09:35 AM
scotts300's Avatar
scotts300
Old Sep 16, 2009 | 09:39 AM
scotts300's Avatar
scotts300
and thanks jacob!
i cant waitt
Psst. Jacob has no effing clue what he is talking about.
Carry on.
Pics of said tires? You have so many pics of your Koukiadkikiaba S14 and you pumped it up for trade all over this forum, you must have pics of the tires? ? ?
Pirelli only makes the Rosso in 305/30/19 and 355/25/19 now. Seems odd that one day they made a totally different sized tire in the same model. I don't think they exist either.
Old Sep 16, 2009 | 09:45 AM
sky14's Avatar
sky14
there at the shop
they could be 25s but from what i remember they were 20s
Old Sep 16, 2009 | 09:51 AM
sky14's Avatar
sky14
u were right they are 25s.
fixed.
scotts300's Avatar
scotts300
there at the shop
Of course they're at the shop. . .
No pics of your Boukaki S14 with them on it? You said they were from your S14 - are you saying you never took one pic of this 245/335 understeering-nightmare-combo ON your car?
Old Sep 16, 2009 | 09:53 AM
sky14's Avatar
sky14
do u have a dick up ur *** or something?
wake up on the wrong side?
ur wife woudlnt put out?
wholy **** all i asked for was would it fit.
u dont want to help out dont need to be a dick about it.
grow up.
Old Sep 16, 2009 | 09:54 AM
Done Deal DR
