Tire Wear
Old Sep 17, 2009 | 11:56 AM
beast66's Avatar
beast66
Default Tire Wear
When I took a look at my tires tonight I noticed the inside looks a lot more worn than the outside (have Toyo T1R 255/35/19). Should I swap my right tire and put it on the left rim and my left tire on my right rim? If anyone agree's to that my next step would be going to get an alignment as soon as possible, and hopefully, that will solve the problem. Btw, I have no drop so no camber issue at this moment.
Old Sep 17, 2009 | 12:25 PM
vthao's Avatar
vthao
You should just get an alignment. If the wear is too bad, swap the tires.
Old Sep 17, 2009 | 02:10 PM
DavesZ#3's Avatar
DavesZ#3
Swapping will work and allow you to get more wear out of them.
Not sure about Toyos, make sure they're not asymetrical and don't allow for swapping inside/outside. They will be marked Outside.
Old Sep 17, 2009 | 05:02 PM
beast66's Avatar
beast66
yea i can swap them...t1r can be switched.
Old Sep 17, 2009 | 08:59 PM
TheFarmer's Avatar
TheFarmer
I plan on swapping mine when the time comes to do so lol.
Old Sep 17, 2009 | 09:03 PM
Escobar's Avatar
Escobar
swap and alignment
Old Sep 21, 2009 | 01:24 PM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
Originally Posted by Escobar
swap and alignment
+1. Make sure they are rotating in the correct direction.
Old Sep 22, 2009 | 10:39 AM
j.arnaldo's Avatar
j.arnaldo
It's a "parallel switch" on unidirectional ones, so no problem. On asymmetrical ones it's a different story, like DavesZ points above. Determine that issue, dude. G'luck!
Old Sep 23, 2009 | 07:05 PM
sandthepilot's Avatar
sandthepilot
tire feathering
sandthepilot
my rear tire blew last night because of that
Old Sep 24, 2009 | 01:58 PM
dhays's Avatar
dhays
Are you saying that your tire failed due to unequal wear? How many miles on the tires, age of the tires, and make/model of the tire?
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
