Looking for 20mm wheel spacer which one?
Old Oct 1, 2009 | 06:11 AM
SimplySimonl's Avatar
SimplySimonl
Default Looking for 20mm wheel spacer which one?
Hi Guys / Girls
I recently got a 20X11 rims running 285 30 in the rear.. i notice is not aggressive enough .. is either i drop a inch all around or get a 20mm spacer for the Rear.. to make it come out... Which Brand would you ppls recommend ??
thanks
Attached Thumbnails Looking for 20mm wheel spacer which one?-brand-new-ride.jpg
Old Oct 1, 2009 | 07:44 AM
Guilty1s's Avatar
Guilty1s
both!!!
i say spacers concidering how bad people point it out when it isnt a good offset... It is cheap too. Then you could start saving for some good coilovers and have that nismo sitting sexily angry.
Old Oct 1, 2009 | 07:45 AM
Guilty1s's Avatar
Guilty1s
ichiba seems to be popular and a good quality brand
Old Oct 1, 2009 | 08:07 AM
SimplySimonl
i know.. spacer is just a spacer.. but does it matter what brand?
is H&R any good???
20mm for the back .. and 10mm for the front?
or should i just stick with the Rear .. and leave the Front alone ..
Old Oct 1, 2009 | 08:13 AM
Zivman's Avatar
Zivman
H&R are good... with a 20mm you will be replacing studs
Ichiba are popular because they have an version that includes a stud on the spacer. thing is, it is not compatable with all wheels. If you get them, you need to make sure that your wheels have clearance within the wheel.
As far as what size to get, you should post up full specs of your wheels saying they are 20x11 is only half the info you need to determine what size spacers to get. Please post up offsets
Old Oct 1, 2009 | 08:50 AM
SimplySimonl
opps is actually 20X8.5 +32 F / 20X10 + 42
Old Oct 1, 2009 | 09:06 AM
pchong154's Avatar
pchong154
Project Kics.
Built-in studs are so much easier.
Old Oct 1, 2009 | 10:10 AM
cheshirecat79's Avatar
cheshirecat79
I thought 20, 25, and 30mm from H&R come with built-in studs?
Old Oct 1, 2009 | 10:52 AM
terrasmak's Avatar
I would just ditch the wheels, usually when you upgrade wheels you don't want to go narrower than stock (you did in the front) i would also be they are heavier that stock, and the offset sucks , actually sucks bad.
Old Oct 1, 2009 | 11:03 AM
skaterbasist's Avatar
skaterbasist
Project kics are top notch.
Old Oct 1, 2009 | 11:07 AM
Zivman's Avatar
Zivman
Originally Posted by pchong154
Project Kics.
yes they are, but they don't work on all wheels.
they come with studs, but not all spacers have built in studs. Regardless, those with built-in studs have fitment issues with some wheels
Old Oct 1, 2009 | 11:32 AM
SimplySimonl
damn foe.. i didnt ask for your opinion on my wheels.. why you hating ! HATERSSSS
Old Oct 1, 2009 | 11:37 AM
doug's Avatar
doug
I have ichiba.. they work great.. i had to roll my rear fenders.. but it was worth it and with Ichiba they come with studs built in
Old Oct 1, 2009 | 05:47 PM
terrasmak's Avatar
Not hating , just putting the truth out there.
BTW i would run ichiba spacers , V1 and wouldn't do spacers with built in studs unless i went 25mm.
Old Oct 2, 2009 | 07:55 PM
SimplySimonl
cool thanks i check it out..
Obadabot
Jun 18, 2023 11:31 PM
