What is this part called?
Does anyone know what this part is called? I need to get a replacement. Some lady cut me off and i hit a curve, and i'm hoping this is all i have to replace.
if you go to order the part from nissan it'll be a pain in the *** to get it. they call it a lower a arm (least when this happened to me last year) the part is about 50$ but will take forever to get it. just order the traction/camber arms if you have the money and you will have a replacement arm faster.
Originally posted by 2003z
that is called the front lower link, according to the service manual.
some guy said it was the camber rod.
and where can i get this adjustable one? or where can i buy a replacement.
So far, i've heard
Lower A arm
Lower link
camber rod
Originally posted by Jun
would it be the REAR lower link then, since it's in the rear?
So far, i've heard
Lower A arm
Lower link
camber rod
So far, i've heard
Lower A arm
Lower link
camber rod
Please select a corresponding number from the illustration below to view the details of that part.
1) Knuckle Right 2) Bushing No. 1 Back 3) Bushing No. 2 Back
4) Bushing No. 3 Back 5) Bushing No. 4 Back 6) Upper cntrl arm Right
7) Lower cntrl arm Back 8) Lateral arm Back 9) Radius rod Back
10) Stay bracket Right 11) Susp crossmember 12) Stopper Stopper Back
Description Year List Price Your Price
Lateral arm Back 2003 $34.13 $25.60
www.nissan-auto-parts-dealer.com
It's a legitimate site, as I've already ordered replacement endlinks through them. Many Z parts will be on backorder, but their price is half of what the dealer will charge you.
John good call on site, that database shows up in many sites including the one I use,
http://www.1stnissanparts.com/oe_parts_catalog.html
just a suggestion, but if that part is bent.. you might want to check the lower control arm and some of the other parts as well if they are bent out of shape or anything.. otherwise the car won't align right
I recently purchased a used Z and found out that that same lower link bar is bent!
I'm upset. I'm hoping this is the only major part that is wrong.
Is the front lower link a black metal bar around 1-2cm's in diamter that aligned parallel to the axle? its roughly about 8-12 inches long and is slightly bent looking?
Could someone give me a part number so I can find pricing? I'd so appreciate it.
[QUOTE]Originally posted by boma
[B]I recently purchased a used Z and found out that that same lower link bar is bent!
Is the front lower link a black metal bar around 1-2cm's in diamter that aligned parallel to the rear axle? its roughly about 8-12 inches long and is slightly bent looking?
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
CFAUVEL
Oct 1, 2015 03:20 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
