Do after market wheels / tires feather if your stock featherd?
Old Oct 13, 2003 | 01:14 AM
KONVERTER's Avatar
KONVERTER
Default Do after market wheels / tires feather if your stock featherd?
Do after market wheels / tires feather if you put them on a car that originally featherd..
someone told me that feathering is caused by bad suspension...
can we get nissan to put a nismo suspension on then? hehe
Old Oct 13, 2003 | 06:19 AM
Audito350Z's Avatar
Audito350Z
Default Re: Do after market wheels / tires feather if your stock featherd?
yes
there are issues with the front suspension on the 350Z that causes the feathering.... dealers are adjusting front alignment to try to fix the problem
probaly not, but it never hurts to ask
Old Oct 13, 2003 | 01:14 PM
Dolfan13's Avatar
Dolfan13
My Dealer dismounted both front tires and cross rotated and alingned the front end...Rides a lot quieter and doesn't bounce as much a lot smoother. The only thing is now you can really see the cupping. It's on the outside.
Old Oct 13, 2003 | 02:04 PM
KONVERTER's Avatar
KONVERTER
cross rotated??
i hope he tire swapped from the rims...
because they are directional tires!
check that out...
oh wait.. reading your post again... they did tire swap because the inside is now on the out
we shall see what happens..
Old Oct 13, 2003 | 02:09 PM
yobri's Avatar
yobri
So basically the alignment (and tire side swapping) is a simple quick fix, right? So what about long term feathering problems? Does Nissan have any plans to fix the problem for the long term?
Old Oct 13, 2003 | 02:32 PM
Audito350Z's Avatar
Audito350Z
The $64,000 question....
I think we are all waiting for the answer to this one.
PeteH
Old Oct 13, 2003 | 04:32 PM
Dolfan13's Avatar
Dolfan13
The tires were seperated from the rims...They had to get approval from Nissan to perform this task. So there must be some kind of TSB on this problem.
Old Oct 13, 2003 | 07:28 PM
uro279's Avatar
uro279
Default I have S-tune
suspension and nismo wheels. Suspension is supposedly right on.
However, do you guys recommend getting adjustable camber/toe kits to ensure proper specs? (I would hate to see my S03's begin to feather!)
If so, which kit?
thanx
Old Oct 14, 2003 | 01:20 AM
Bahraini350Z's Avatar
Bahraini350Z
I have a stupid question!!!! What is feathering??? Been hearing a lot about it!! Is it allignment problem?? coz my car pulls to the right!
Old Oct 14, 2003 | 05:57 AM
uro279's Avatar
uro279
Feathering is uneven tread ware on tire.
Do a search and look through because there are many pics.
Also, my car pulled to the right after changing the suspension and wheels/tires.
After four attempts to align, it was found that the screw to the control arm was not screwed at all. They believe it came this way from the factory. Others appeared to have the same problem.
Anyway, it's hard to find that this is the problem depending on how the car is lifted to align. You have to ask them to lift the car on the chassis, not on the control arm. Otherwise, problem may be missed.
Hope this helps your prob..
PS FYI, if you believe something is not right, persist by having it rechecked or go to another alignment shop(sports car specialist a best) and getting it checked out.
Old Oct 14, 2003 | 07:27 AM
jj1814's Avatar
jj1814
Dolfan and Bahraini350Z, go to the 'Repairing' forum for more info.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
dcains
Nov 11, 2015 11:36 PM
kyin
Oct 15, 2015 05:54 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
