please HELP! iam about to lose my mind!
Old Oct 9, 2009 | 09:22 AM
jcer's Avatar
jcer
Default please HELP! iam about to lose my mind!
I got 20" sevas for my car and after a year I finally saved enough money for the tires and when I went to put them on this morning the rears did fine but my front WONT FIT! the pattern just I dont know doesnt want to go in !
Iam so upset if any one gots ideas or anything please help !
Old Oct 9, 2009 | 09:36 AM
dhays's Avatar
dhays
Take a deep breath and calm down so you can actually put a sentence together so we can understand what you are saying.
Are you saying that you can't get the bolts to line up with the holes in the wheels? Does the wheel/tire combination not fit within the fender? Be a little more specific and maybe folks can give some advice.
And let me be the first to say that your initial mistake was thinking that 20's' belonged on a sports at all.
Old Oct 9, 2009 | 09:48 AM
scotts300's Avatar
scotts300
What is the exact problem? The front lug holes don't match the stud pattern?
And I have to ask, what is your jacking point in this picture?
And I thought you "put these bad boys" on your car about a week ago?
https://my350z.com/forum/7796631-post1.html
Old Oct 9, 2009 | 09:50 AM
terrasmak's Avatar
Just install your 20's on an SUV, but if you must make your Z look Ghetto read the top 100 and figure out if your doing something wrong.
I'll bet it covered there, not to mention just about anyone who didn't get raised on Nintendo could figure it out without reading the top 100.
Old Oct 9, 2009 | 10:01 AM
JSia's Avatar
JSia
did u remove the 2 small bolts on the fronts before putting them on
Old Oct 9, 2009 | 10:24 AM
SnyzzleZ's Avatar
SnyzzleZ
what size tires do you have for the front... check the size on the inside of the wheel to make sure its right.
Old Oct 9, 2009 | 10:28 AM
Flee0588's Avatar
Flee0588
Relax. There is a little screw on the caliper. Take it off, problem solved.
Old Oct 9, 2009 | 11:44 AM
scotts300's Avatar
scotts300
You and your real solutions.
Old Oct 9, 2009 | 11:50 AM
jcer's Avatar
jcer
iam sorry I just worked really hard for stuff not to go in right
I cant get the bolts to line up with the holes in the wheels
And for the jack I really have no idea thats like 6 mth old pic lol
Tire size are 245/35/20 front
Rear 275/30/20
What screw??
2 small bolts???
Thanks again guys for the help iam just stress'N!
Old Oct 9, 2009 | 12:18 PM
terrasmak's Avatar
I would probably get the proper size front tires before you drive on them. 245/40-20, Better yet , get rid of the dubs and get nice wheels.
Old Oct 9, 2009 | 12:37 PM
DavesZ#3's Avatar
DavesZ#3
Wow. This whole thread reeks of failure. Without all the details, it's hard to know for sure.
OP - does the front hub appear to have 6 studs instead of five? Five regular threaded studs then a sixth one, out of place, no threads? It appears to be a hex head bolt through a small steel cylinder? If so, read post #2 in the Top 100 Questions thread, please.
Do you have a base model Z? If so, good. If not, you are going to have problems with TCS/VDC based on the tires sizes you listed.
I can't believe with a year worth of planning, these two simple problems are going to throw a major wrench into the works.
Old Oct 9, 2009 | 12:54 PM
Jay'Z's Avatar
Jay'Z
How many sets of holes are on the wheel?
All you have to do is take a bigger drill bit and drill the holes bigger!! Prob solved!! Unique auto does that all the time!!!
Old Oct 9, 2009 | 01:18 PM
jcer's Avatar
jcer
5 holes on wheel
ill take picture's when I get a chance
hub has 5 also
Old Oct 9, 2009 | 02:38 PM
DavesZ#3's Avatar
DavesZ#3
Is the back side of the hub stamped with 5x114.3 or is there a label that specifies that bolt pattern?
Old Oct 9, 2009 | 05:10 PM
KornerCarver's Avatar
KornerCarver
Since the back wheels seem to fit correctly, why don't you just try to mount a rear wheel on the front? If it fits, then the wheels you bought for the front must have an incorrect bolt pattern.
Old Oct 9, 2009 | 06:24 PM
jcer's Avatar
jcer
Thanxs for any helpful advice I got so far I will retry 2mrw and let u guys kno whats up thanks again!
Old Oct 9, 2009 | 06:38 PM
SnyzzleZ's Avatar
SnyzzleZ
those are the sevas i believe.. with a nismo sticker.
Old Oct 9, 2009 | 07:32 PM
gyotar's Avatar
gyotar
I have this exact setup with no VDC or TCS problems...
Old Oct 10, 2009 | 05:54 AM
DavesZ#3's Avatar
DavesZ#3
Wait, aren't you the guy with a couple other threads with "ABS & Slip problems"?
Old Oct 10, 2009 | 06:03 AM
gyotar's Avatar
gyotar
ABS SLIP VDC OFF lights you mean? Yes caused by a malfunctioning cam position sensor. Resolved when I replaced it. Why would I mislead this gentleman?
