Tire rubbing issue
Old Oct 16, 2009 | 04:23 PM
350Zsmokinyou's Avatar
350Zsmokinyou
Default Tire rubbing issue
Ok i am dropped on eibach sportlines. I have an spc rear camber kit set at 1.7 neg camber on both sides. Running 19x10 +20 offsets on the rear with 275/35/19.
I went from 275/30/19 and had about a pinky of clearance under full compression. Now i have about 1 millimeter of clearance under full compression. It rubs very slightly from sidewall flex i guess. Very slightly. Doesn't look like it is cutting the sidewall. Is this something i should be worrying about or is it ok?
What can i do?
Old Oct 16, 2009 | 04:27 PM
calin's Avatar
calin
That's strange. I'm also dropped on Eibach sportlines and SPC camber kit and I have 19x11 +23 wheels in the rear with the same tire sizes you have and I have quite a bit of clearance with my rolled fenders. It's probably about a finger width. Are your fenders rolled?
Old Oct 16, 2009 | 04:29 PM
350Zsmokinyou
They are not rolled.
Old Oct 16, 2009 | 04:37 PM
calin's Avatar
calin
Roll them! rubbing fixed
350z82
Oct 1, 2015 06:25 PM
