will 19s create more wheel gap
Old Oct 27, 2009 | 04:05 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Default will 19s create more wheel gap
Planning on getting a set of 19s next week on 35 profile tires and was wondering if with that combination I will have more wheel gap then I have now (currently stock) Planning on getting the gruppe-s bumper as well so really don't want to have to lower my car. How will it look at stock height. Anyone have pictures of 19s at stock height?
EDIT: Here are sizes
19x8.5 on 245/35/19 20 offset
19x9.5 on 275/35/19 20 offset
Old Oct 27, 2009 | 04:14 PM
terrasmak's Avatar
The gap will be the same if you buy the proper tires, and will look fine if you get the right offsets.
Old Oct 27, 2009 | 04:22 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
posted tire/wheel/offset sizes in first post
Old Oct 27, 2009 | 04:24 PM
FATPUBUS's Avatar
FATPUBUS
Heres mine before and after with 19 inch 285/35 rear...the gap is kinda the same to me anyway
Old Oct 27, 2009 | 04:26 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
what offset are those
Old Oct 27, 2009 | 04:41 PM
FATPUBUS's Avatar
FATPUBUS
Oh yea, sorry...f+21 9.5", r+24 10.5 inch. f 245/35/19, r 285/35/19
Old Oct 27, 2009 | 04:56 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
so i could be fine then, I hope.
btw you forgot to scratch out your license, now im gonna come looking for you
jk
thanks for your help though
Old Oct 27, 2009 | 05:03 PM
StevieZ's Avatar
StevieZ
I have the same size/tire setup & off-set (slightly wider rims) and found that the gap actually reduced a little. You should be ok. I think you will probably end up getting the ProKit (or something) to drop it a little...
Old Oct 27, 2009 | 05:18 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Eibach Pro, they seem pretty affordable to at around $250
Along with lower will those give a rougher more stiff ride?
Old Oct 27, 2009 | 05:42 PM
Nexx's Avatar
Nexx
all depends on the tires sir.. all on the tires.
90zebra's Avatar
90zebra
Your gap will be increased 2/10 of an inch in the front and 1/10 of an inch in the back with the tires you are running.
Old Oct 27, 2009 | 06:32 PM
zerafian's Avatar
zerafian
it will be minimal...235/50 on 17" rim, 275/45 on 18" rim, 295/30 on 19" rim...I have used all 3 of these in the rear and I would have to have 3 pictures taken at the exact same angle of each to even notice the slight difference in gap.
the profile number will make the biggest difference in fender gap
Old Oct 28, 2009 | 09:15 AM
scotts300's Avatar
scotts300
Depends what size tires you are comparing them to. You can use the tires sizes to calculate the total height.
Old Oct 28, 2009 | 04:29 PM
Mike@Blackline's Avatar
Mike@Blackline
http://www.miata.net/garage/tirecalc.html
Old Oct 28, 2009 | 06:36 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
what on there tells me how much more of a gap i will have.
Old Oct 28, 2009 | 06:38 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
compare your before to your after and you will see the differences in the calculator
Old Oct 29, 2009 | 02:00 AM
Mike@Blackline
350z82
Oct 1, 2015 06:25 PM
