Can Z tires be rotated?
Technically you could swap the tires by removing and remounting them on opposite wheels. But thats not the way the tires were designed, because then you have the outside of the tire on the inside, and vice a versa. If the tread pattern is symmetrical side to side this probably wouldn't be that big of a deal, but I doubt the tire shop would do it.
If you just swap the wheels yourself, the directional (or asymmetrical) tread pattern is pointing backwards and will cause weird tread wear. Because as far as your tires are concerned, your essentially driving in reverse more than forwards.
Most tires i've seen will say "Rotation" and be inside of an arrow pointing which way the tires are supposed to rotate when driving forward to make sure they are mounted properly.
Just live with them for awhile if there isn't too much wear from the negative camber on the outsides.... otherwise it's time to buy new ones.
Both can be swapped left-right on the vehicle. The directional tires you have to dismount off the wheels and then swap, whereas the asymetric ones you just take the wheel/tire assembly off and put it on the other side.
Directional is NOT the same as asymetric. Acutally, in most cases they are opposite - an asymetric tire can be mounted to rotate both ways, and these are the ones that say "outside" or "inside". Directional tires can only go one direction and have the rotation arrow.
BTW: It’s not asymetric, but rather asymmetric.
--Spike
Yes I think I have that kind on the 370Z. At about 10,000 miles I will put the inside on the outside and outside on the inside. See if I can cheat death!
David’s posts are short, but they go very deeply. He is certainly one of the more interesting commentators here. I really like reading his stuff.
--Spike
Reference: http://www.tirerack.com/tires/tirete...jsp?techid=188
^^ Interesting reading… Your point is well-taken. We are always looking for “absolutes,” but in the real world that is rare. It’s mostly compromises that we are dealing with. Automotive tires are a good example.
--Spike
--Spike
Just making sure - if there's one thing you've taught me Spike, it's that people can totally misunderstand the simplest things.
It's not just about rotating tires, but rather determining the best options for extending tire-life and tire replacement.
--Spike
Falken FK-452s look like they are symmetrical (http://www.falkentire.com/Tires/Passenger-Car/FK452-3)... I've tried searching and didn't find out whether they can be rotated or not... Do you guys know?
I’m sure he knows (really… not kidding here).
--Spike
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
