question about the 3% rule
Old Dec 16, 2009 | 09:37 PM
lemmiwinkz's Avatar
lemmiwinkz
Default question about the 3% rule
i have the vdc in my z and i found that when getting new tires you can need to keep the rear tire larger than 3% of the front tire but still larger than the front tire. however i cant seem to find any info on how low you can go. i was thinking about a 265/35 r18 front and a 285/35 rear which would be about 2.17% which is lower than 3 but is it to low??
Old Dec 16, 2009 | 10:26 PM
Nissan does not publish VDC operating parameters. And if they do it is so complicated that I could not figure it out. That said I would be cautious with this set-up.
Old Dec 16, 2009 | 10:57 PM
terrasmak's Avatar
Originally Posted by lemmiwinkz
i have the vdc in my z and i found that when getting new tires you can need to keep the rear tire smaller than 3% of the front tire but still larger than the front tire. however i cant seem to find any info on how low you can go. i was thinking about a 265/35 r18 front and a 285/35 rear which would be about 2.17% which is lower than 3 but is it to low??
Just fine, the % you have to worry about is the difference between front to rear tire height.
Old Dec 17, 2009 | 03:18 AM
DavesZ#3's Avatar
DavesZ#3
Fixed for ya.
Old Dec 17, 2009 | 04:51 AM
lemmiwinkz's Avatar
lemmiwinkz
Smile
^thanks for the fix
Old Dec 17, 2009 | 05:40 AM
Brrcats's Avatar
Brrcats
you'll be fine with a 2.17% difference, i think you can actually run a square set up without vdc issues
Old Dec 17, 2009 | 07:31 AM
GeauxLadyZ's Avatar
GeauxLadyZ
As long as you keep within 3% front/rear height difference, your good to go.
3% rule is the operating parameters of the VDC, David.
Old Dec 17, 2009 | 09:51 PM
lemmiwinkz's Avatar
lemmiwinkz
ok cool thanks guys
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
